1st, remove the two screws from above the USB ports.
Then pop off the sides of the console. Each side is held on with (supposedly) 7 clips. Just push the top out and use a screw driver to pry the bottoms ones out.
View attachment 270256 View attachment 270257
Then remove the screw with the big washer from each side (at the top, just left of center)
Then "gently" shove the unit forward until you have some space at the back and lift it out, back edge first. Be careful not to scrape the arm rest.
Then you vacuum, and in my case, clean out dropped parking tags from previous owner. Then just press-fit the EVamped unit into place pushing down and forward to clear the power port.
This is the "Low" unit that sits below the USB and 12V. They also have a "Tall" unit that covers them. Oh, and I got the USB ports as an option.
View attachment 270259 View attachment 270260 View attachment 270261
