  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Has anyone joined a utility program using fleetcarma's OBD2 device?
I think the program length varies based on what kind of deal the individual utility made with FleetCarma. There are a bunch of folks in BC who have used their service, so maybe one of them can shed some light for you.
I have a unit on our Smart that's been running for several years, but it is grandfathered in from on old Toronto Hydro pilot program.
With a Tesla you'd likely need an adapter for the standard dongle.
There's another thread on this for BC residents. I'm currently participating in the program. It provides charging, driving and whole bunch of data to you and the program. I might eventually disconnect it, as it feels like it's gathering too much data.
I'm hoping these data helps to roll out more EV programs. That's only reason I kept it for now.
I thought Teslas dont have an obd2 port? Even with an adaptor, would the communication protocol work?
Yes there are third party adapters/cables.
I've just ordered a couple to get more stats through the scan my Tesla app (especially battery related ones, you can get total kwh of battery which should give an idea of degradation, also can see current max Regen level, I believe max is 85kw and 110kw in track mode).
Reactions: pcons
Let me know how it works. I have an obd2 Bluetooth module I used to use with my volt. I miss the extra info. How much was the cable adapter?
I got 2 different ones just in case one doesn't work the geotab one is cheap $35 us plus shipping but supposedly only works on pre 2019 model 3s. The other one is 75 euros but you have to mention you have a pre 2019 car since they default to the post 2019 version (but they have versions for both).
In both cases you need an obd2 adapter that supports can bus fully so some cheap ones don't work. The expensive cable comes with a compatible adapter for an extra 20 euros and that bundle comes with a free copy of scan my Tesla a $12 value.
Hi pcons. I tried the geotab cable with the MX+ Bluetooth adapter. It works and shows me my nominal full pack is 72.1kwh which points to some level of degradation, though I don't know the original factory fresh level, I do know that Tesla Bjorn was getting 74kwh and then 73.5kwh.
It's nice to see the total AC and DC charges and also the regeneration total. Mine is almost 20% at 1994kwh total Regen if that stat is accurate.
Also shows battery temperature etc.
Reactions: pcons
Good to know. Any interest to meet up for a coffee and scan my car for a second data point? Would give me a chance to see if its worth the hardware investment. I'll buy the coffee :)
