We got our first Tesla March 27 which was a 2022 demo M3 Performance from Tesla dealer. Love the car but have a couple issues. The glove box light did not work and while researching that I saw how the glove box was supposed to open which was soft and ours just fell open. The other issue, hence why I am replying to this thread,
has become much more serious which is the power lift gate.
The first couple times we opened the lift gate it worked fine, but then it would open halfway, beep twice and stop. I researched on this site and found a few current posts about this issue and that said it was a software update that caused the problem. Couple days later we got an update, and the issue was
not resolved. I also found a thread that explained how you could recalibrate the lift gate by opening all the way, manually in our case, and holding in the close button until it beeps several times. Tried that and it did not fix the problem either.
So, I entered a Service request on the app for the glove box and the
lift gate. Mobile tech arrived and swapped out the glove box fixing that issue. Then he looked at the lift gate and quickly said it is not a software problem. He said he thought the power actuator arm was bad or bent. He said to enter a new Service request which I did. The part had to be ordered and took a couple weeks and while waiting on that the lift gate got worse and would no longer open at all. It would just beep and move slightly. I reported the problem had worsened on the ticket and they did come out earlier than was then scheduled.
The next mobile tech then installed new actuator arm and it made it ever worse. Now the lift gate will not close and catches on the rear glass and the metal on the other side. The Tech was stumped and after trying several things including adjusting the hinges decided she could not fix it and I would need to come into the service department. It took us a good while to finally get the lift gate closed and it very misaligned now dropping way below the pillar on the left side. The Tech said she had never seen anything like it. Scheduled to take it on Friday 4/29/22 and leave it. Hopefully they can figure it out. Little concerned about the paint that has been scrapped off on the edge of the lift gate from hitting the glass and pillar on the way down.
In the pictures you can see at first when it opened partially and then the next 3 are from yesterday after the second Tech was here and we had so much trouble closing it and how it has dropped down way lower than is should be.
