Has anyone upgraded their 14-50 to a hpwc?
Discussion in 'Model X: Battery & Charging' started by LuckyX, Oct 25, 2016.
  1. LuckyX
    LuckyX Stormtrooper X60D, Autopilot, and Hitch
    Orange County
    Currently have a 14-50 (50a) setup at the house but would like to upgrade to HPWC. How difficult it is to DIY?
  2. mknox
    mknox Well-Known Member
    Toronto, ON
    What I did is go out and buy a stove cable set from Home Depot similar to this and simply wired it into the HPWC and set the DIP switches for 40 amps delivered. I then just mounted the HPWC near the outlet and plugged it in.
    If you're looking to get the full 80 amps from the HPWC (or anything higher than 40 amps) you'll need to re-wire as the circuit to your 14-50 will not likely be adequate.
    • Informative x 3
  3. LuckyX
    Orange County
    @mknox interesting! Seems like like a good option. I may go with this route as it seems easy. Currently I won't go up to 80a.
    I'll have to see if it will pass building code/permit.
  4. mknox
    Toronto, ON
    There was nothing in my HPWC installation manual specifically prohibiting this, which is where code requirements would come in, but checking local codes would certainly be the prudent thing to do.
    I just went ahead and did it. I figure it's no different than an electric range, which is (or should be) fastened to the wall to prevent tipping, and is also plugged into a NEMA 14-50 outlet
  5. LuckyX
    Orange County
    Yea logistically it all makes sense. I'll probably just run with it. If I don't pass Im not out much with the cost of the wire.
    Thanks for the insight!
  6. Canuck
    Canuck Well-Known Member
    South Surrey, BC
  7. BerTX
    BerTX Supporting Member
    Texas/Washington
    I guess I virtually upgraded, since I was installing a 14-50, then upgraded to the Wall Connector before actually installing the plug. I realized that the particular wire to my plug was sufficient to run the Wall Connector at 48 amps, rather than the 40 amps of the Mobile Connector. I was going to buy an extra, dedicated MC, but then realized I could get the extra bit of power from the Wall Connector for just a few dollars more, I switched and got the Wall Connector.
  8. davewill
    davewill Member
    San Diego, CA, US
    It's also pretty easy to remove the outlet and use the box as a junction box to wire the HPWC in a more traditional manner, although you may be required to add a cutoff switch near the HPWC in that case (the plug acts as the local cutoff when using a plug).
  9. mknox
    Toronto, ON
    Being the "belt and suspenders" kinda guy I am, I already installed a 60 amp disconnect switch adjacent to my NEMA 14-15 in the garage. I didn't like the idea of plugging or unplugging anything into that outlet while powered, especially with the potential of a wet floor in winter conditions when snow/slush drips off the cars.
  10. LuckyX
    Orange County
    @mknox I just about have everything ready however I can't seem to figure out where the green cable connects to in the HPWC.
    Currently
    Black to L1
    Red to L2/N
    White to ground
    Green to ?
    I purchased the 4 prong (range cord). Nema cord 50amp 4'ft (black, red, green, white wire exposed.
    Help please.
  11. LuckyX
    Orange County
    What do I do with the white(neutral) wire?
    My mistake.
    Black to L1
    Red to L2N
    Green to ground
    White(neutral) to ? (Do I just cap off)
  12. mknox
    Toronto, ON
    You don't use the white wire, so just cap it off. Technically, the NEMA 14-50 is a 120/240 volt socket, but the HPWC (and most EVSE) are just 240 volts. The neutral is needed to get 120 volts between it and either the red or black wires.
  13. Dstrohl
    Dstrohl Member
    Seattle Area
    For what its worth:
    CAN I ATTACH A CORD AND PLUG TO MY HPWC AT THE 50A SETTING?
    In several threads on this forum, some have asked whether they may use their HPWC plugged into a NEMA 14-50 receptacle; this would allow them to unplug it and use their UMC in case of a wall connector failure.
    Technically, there is nothing in the NEC that prohibits the practice; Tesla's instructions don't explicitly call for only permanent wiring methods, and article 625 permits 240V devices to be plug-and-cord devices as long as they're "fastened in place". The only restriction is that the segment of cord prior to the ground fault protection (HPWC) must be a maximum of 12 inches in length (NEC 625.17(A)(3)(a)). Proper connectors, clamps, and strain relief connectors must be used.
    When consulted on the compliance of such a solution, several municipal and county inspectors have determined the practice to be legal based on the current instructions published by Tesla, and the NEC's requirements.
    However, when consulted, Tesla expressed concerns about the practice. The charging team responded to an inquiry with an explanation that the HPWC is designed to be mounted on a wall or post and wired using permanent wiring methods. There are concerns that a power cord could be yanked from the HPWC's terminals and expose live wires if, for example, someone or something grabbed the cord and yanked.
    A suggestion was made that Tesla note in the instruction/installation manual that permanent wiring methods are required, which would then be required by the NEC per section 110.3.​
  14. mknox
    Toronto, ON
    Yeah, I'm well aware of that from the FAQ. I am in Canada where the rules are largely harmonized with the US, but there are some subtle differences.
    I do wonder one thing about this 12" rule since I don't have a copy of the NEC: Is this specific to EVSE only? They seem to sell these somewhat longer cables in the US just like in Canada, and presumably they allow longer cords on stoves and dryers. I'm hard pressed to see what the difference is between one appliance connected to a NEMA 14-50 and another.
    You can always cut the Home Depot cord set down to 12" if this is a concern. I didn't.
  15. Dstrohl
    Dstrohl Member
    Seattle Area
    Well, I know that cords are covered in several places, but the specific reference this is from is:
    • 625: Electric Vehicle Charging System
      • 17: Cords and Cables
        • A: Power Supply Cord: The cable for cord connected equipment shall comply with all of the following
          • 3: Have an overall length as specified in 625.27(A)(3)a. or b. as follows:
            • a: When the interrupting device of the personal protection system specified in 625.22 is located within the enclosure of the supply equipment or charging system, the power supply cord shall be no longer than 300mm (12") long.
            • b: When the interrupting device of the personal protection system specified in 625.22 is located at the attachment plug, or within the first 300mm (12") of the power supply cord, the overall length of the cord shall be a minimum of 1.8 meters (6') and shall be not greater than 4.6 meters (15')
    So... this is specifically for EVSE's... (but that doesn't mean that other cords do not have a specific one).
    BTW, this is from the 2017 NEC (NFPA 70: National Electrical Code®) which you can access for free (after registering).
  16. DaveWaterloo
    DaveWaterloo Member
    Waterloo, Ontario, Canada
    #16 DaveWaterloo, Nov 5, 2016
    When I had my HPWC installed, I insisted that it be plugged into a newly installed NEMA 14-50. (just in case I moved, I wanted the option of taking the HPWC with me). Ontario, Canada.
    The Electrician insisted that the ground had to "face left/right side" and I asked him to show me the code where it did say "must face a side" or similar.... I said great I wanted to face the "top side" (I didn't want an unnecessary turning radius) . And it just seems safer to not have gravity working against you. The electrician opined that the inspector would not approve it.... so I asked can we give him a call? The inspector said he was ok with it.
  17. mknox
    Toronto, ON
    That is virtually identical to my setup, right down to the armored cable feeding the NEMA 14-50. The only difference is that I opted for a 60 amp disconnect switch beside the outlet and had it mounted higher on the wall. I was worried about plugging/unplugging while live... especially while standing on a potentially wet garage floor.
  18. LuckyX
    Orange County
    Got my wall charger up and installation was pretty easy after the tip to cap off the neutral wire. Now to wait for my X to came back from service to test it out.
  19. outie
    outie Active Member
    SoCal
    @LuckyX What's wrong with your car?
  20. LuckyX
    Orange County
    A laundry list of alignment issues. Both fwd squeak in restricted areas. Debris and scratches in paint/topcoat (hood). Squeaky brakes. Nothing major, just preferred to knock it all out now prior to getting it opticoated and chrome deleted.
