Note: This feature currently requires accessing the site using the built-in Safari browser.
I may have been misunderstood when i said " I'm not sure this is is acceptable"Ask for you money back
Have you posted your concerns on the upgrade thread? As VanillaAir said, there's a whole plethora of devices out there and there may be configuration changes needed to accommodate them all.
Interesting you should mention Speak EV. When I first saw the new format, Speak EV came to mind. I wonder if they are using the same software, hence there may be a config change that will sort out your issues.
...by the way was the green 'online now' indicator visible somewhere previously? (my wife already tells me about how much of an 'idle waster' I've become so thanks for confirming that TMC)
I can't see blobs for anyone, green or otherwise, so guessing it's a moderator level thing.
Its still work in progress. The unread posts is a known issue and a better solution is being looked into by the site admins. Unfortunately, its not helped by different devices and preferences causing things to render different.
tbh, I wouldn't go trying to find a workaround unless its causing major heartache. I am sure a better global solution will drop out in the wash in due course.
The new unread threads notification has rolled out if you have not noticed it.
