brkaus
just curious: you said 600miles and no leak...what if the nail is short that it hasn't even got into the tire enough to cause a leak? Only way perhaps to find is do an xray
These days I drive up to a tire shop parking lot and then pull out nails/screws/etc that I was not sure about. Most times I have been lucky and they didn't go all the way through. Sucks to pull them at home and end up with a flat tire - been there, done that.
So the tire certificate/warranty is provided by the tire seller. For new Teslas with factory tires, one cannot buy the hazard warranty?
Yes, discount tire will sell a certificate on nearly any tire, even if not purchased from them. They make a ton of money on the certificates or they wouldn't be doing it. They get $38.50 per tire for hazard certificate for a Michelin Pilot Sport PS3 ($225 per tire new). So if you have one tire damaged by road hazard you have saved $72 on the replacement. I'm guessing that is still under their cost. Plus, you have to pay for balancing, valve stems, TPMS kit, etc for the new tire and of course new replacement certificate. Many times, they end up selling the other 3. They likely come out ahead in the majority of the cases.
It's not that close to the sidewall. It's repairable.
I tend to agree with this. Tire shops used to patch anything and everything. Then only the tread area was OK. After that, it had to be within the outer most groves. Now they also look at the date of manufacture of the tire. Sure, there is some risk. I'm wondering when they won't patch a tire at all.
I've ordered a plug kit to carry in the car.
