Hawaii Tesla Model S accessories
WeazL
Moderator - Hawaii
Aug 18, 2013
614
29
Oahu, Hawaii
I imagine that you could replace an existing set. But indeed, they should not be installed in a vehicle that does not already have them as the rear frame assembly is reinforced if the seats are installed at the factory. This vital reinforcement is not present in vehicles not factory equipped with rear-facing seats.
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,324
4,452
Kaneohe, HI
How do we know? We know that was true back in '13 because it was explained by Tesla at that time. But they change things and they do not come back tell us things have changed. How do we know that its still true? How do we know that not all frames after a certain time are the same whether the order included the rear facing seats? Its common to find someone on TM to ask about a set. So, I am still asking if anyone is interested in rear facing seats. If someone is interested, contact me.
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,324
4,452
Kaneohe, HI
Ya know how the Daytime Running Lights makes the front of a Model S look like its got eyebrows? Well, I thought I would add a smile to mine. If you see me coming from the opposite direction, I will try to turn on my smile for you.
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,324
4,452
Kaneohe, HI
Happy to answer this. Its simple.
LED Lighting waterproof strips and connected to a small fuse box with a remote controller between the negative and positive terminals on the support behind the nosecone. I can turn if on and off with a 12V remote controller that I picked up on Amazon for $17.00
This is mounted with sticky back side LED strips on the chrome lower section of the nosecone. These have a white background and more obvious. I have some on order that are black background with bright white LEDs because these will not be noticed as easily. These strips were cut from a 16 foot reel that didn’t have connectors. I used the strips to measure from the center of my lower section under the nosecone and up to the curve of the smile about half way up the side of the nosecone. I needed to use a 30+ inch section on each side, because my front camera is mounted in the center of the chrome under the nosecone. That’s why she looks like she’s missing a tooth in the middle. If the adhesive doesn't stick well, add a little clear silicone to help it.
I needed two each two conductor small wire lengths about 18 inches long. I soldered these sections to the end of the LED strips and insulated them with shrink wrap. Feed it up through the heavy steel support behind the nosecone. You want to use small/thin wire so it won’t be pinched into by the end of the nosecone when snapped back into place. One strip is each side. It may be simpler to buy three foot lengths of sticky backed white LEDs with wire already attached, and avoid the effort of soldering wire on LEDs.
Of course you want to fuse the power. I used a small fuse box and got power from the two terminals behind the nosecone. Added a small 12V controller sealed in a small black box with a handheld remote that I hang on the turn signal. It’s on and off with a red LED that tells me when I press the button. I can’t tell if the strips are turned on or off. So, I need to manually check to insure I am not leaving them on if I don’t want them on. The controller has two remotes. One can stay in the car and the other in my pocket when I am out. Then if I see I left the lights on, I can turn them off without going back to the car.
Once it’s wired up with the strips hanging from the ends of the nosecone opening, pop the nosecone back in. Then starting from the center of the chrome lower section of the nosecone, peel the backing off the adhesive strips and lay it on the chrome lower section and route it up the curve of the chrome to form the “smile”. Do the other side.
Yesterday and passed a Model S going in the other direction. When I had spotted his Daytime Running Lights, I had time to press the remote button on and off twice so I “smiled” at him twice before he passed. Even in daylight the lights will draw attention as the toggle on then off. I can drive with them on too.
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,324
4,452
Kaneohe, HI
Have you folks here been following artsci's effort to add a light effect to the rear applique on the back of the Model S? I ordered and recently received mine. I installed it last weekend. Its an amazing mod for the Model S. Don't dismiss this as a simple lighted name. Its tied into the brakes, the running lights, the turn signals and the backup lights. And it produces a "disco effect' if you are so inclined. ;)
Here's some links to more details on TMC with video demos of what it does. And there's also a separate web site so you can get even more info. And a close up of mine. EVAppliques TMC Links:
Tesla model s gen ii lighted rear appliqu㉠with special effects, bluetooth smart phone controller,
Model S Lighted Rear Applique in operation on the road
drtko147
1,086
161
Waialae Nui, Hawaii, United States
I have a Pebble Time Steel watch and here are some of the photos of the features available.
nanimac
Aloha!
Nov 27, 2012
2,426
567
Oahu
Is that the Tesla app? I use Remote S on my apple watch but iphone has to be near. Haven't tried remote start either..but have accidentally used homelink to open my garage door from inside the house. o_O
