Hazy Model S windshield
Discussion in 'Model S' started by Ken7, Oct 5, 2018.
  1. Ken7
    Ken7 Member
    New York
    I’ve had my MS about 1 year and I’ve always noticed the windshield seems to have a slight haze to it relative to other cars I’ve driven. It’s particularly noticeable when driving into the sun. When I get into my wife’s Honda Clarity, the view through the windshield just seems more ‘transparent’.
    I’m not sure if this is normal and related to a UV coating. I should mention this is not the ghosting issue that some discuss. Night driving presents no double images or ghosting.
    Has anyone else noticed this?
  2. CaliMS
    CaliMS Member
    I washed mine with glass-wipes shortly after i got the car and had a haze I could not get off. I had washed the car and the haze was still present. When I was at Tesla I mentioned it and they washed it with [something] and its was clear again. Threw away the wipes.....
  3. BinaryField
    BinaryField Member
    Earth
  4. Rockster
    Rockster Active Member
    McKinney, TX
    Are you certain the problem is on the inside? Could it be on the outside? After 70,000 miles, my Model S windshield was a mess. When the sun hit it I could barely see because of thousands of specs of some sort that were on the outside. I bought this clay bar designed for glass and, in conjunction with some spray detailer, made the windshield look nearly factory new in less than five minutes.
  5. Ken7
    Ken7 Member
    New York
    Interestingly, I have used that exact cleaner with no success. It doesn’t look like the light haze is a residue of something, but rather inherent in the glass. Of course I could be wrong. It’s been there since the day I picked up the car. I know the film you’re talking about and I’ve certainly had that in many cars. The difference is I’ve always been able to get it off with various cleaners.
  6. kirky
    kirky Member
    Norway
    Yeah also have some haze feeling in direct sunlight, not as transparent as other cars I have used... Maybe it needs some sort of cleaning maybe its the glass...
  7. cab
    cab Member
    Grapevine, TX
    Some of it is definitely the angle of the windshield. Beyond that, if you do have a film of some kind (often very evident when raining as you will get wiper smear), I've used Meguiars Cleaner Wax as it simply "cuts" throigh that film way better than regular glass cleaners. As a process I clean the glass with glass cleaner (Sprayway or Invisible Glass), "wax/clean" with the Meguiars cleaner/wax, let that dry and then buff the residue, and then to remove the wax I clean again with the glass cleaner. I might be able to eliminate the second glass cleaning if I just used something like one of Meguiars light mirror glaze products w/o any wax, but the "chemical" cutting of the Cleaner wax is what does the work vs. any real abrasive in some of their other products.
  8. Ken7
    Ken7 Member
    New York
    I always thought using a wax on the windshield was a no no.
  9. cab
    cab Member
    Grapevine, TX
    I think the issue with wax is that it can actually make the windshield "too slick". When it rains, the wipers swipe back and forth and actually need a little friction to allow the rubber blade to "flip over" at the start of each (up or down). You will notice that I am doing the wax/cleaner (really for the "cleaner") and then using a regular window cleaner afterwards. The latter is to essentially remove the wax. Indeed, right after I wax it, the glass is slick as can be. One swipe with the glass cleaner and it is "squeaky" clean again and the slickness is gone.
  10. DMack
    DMack Member
    Oakland
    Have you had ceramic coating done on your car?
  11. st50maint
    st50maint Member
    New York
    Similar problem from 4 years ago. This gentleman recommended baking soda.
    Windshield residue!
  12. P85DBeast
    P85DBeast Side tEsLa
    Atlanta, GA
    I've never had this issue before. I never wipe my windshield with anything other than Rain-X. I only wash the car with Rain-X and I accidentally used Awesome cleaner on my wheels... I almost had a panic attack, thankfully it washed off and left no damage.
  13. PhilDavid
    PhilDavid Active Member
    Philadelphia
    If all else fails, thoroughly clean the inside glass with a quality glass cleaner and then claybar the interior glass.
    I recommend everyone claybar the outside windows about once a year. You'd be surprised with what it would pick up!
  14. Ken7
    Ken7 Member
    New York
    No, never did any coating.
