davezforce
IG @davezforce
Gotcha. Makes sense. I have the kit for my X but haven’t installed it for this reason. I can’t believe no one has made a T harness or something to go in line get a direct Line In Aux cable.Appletv doesn’t support Bluetooth to a vehicle (try pairing your appletv now to your vehicle and see it won’t work). You need to extract audio from hdmi out and transmit it using an external Bluetooth transmitter. Whether that transmitter supports a delay is an issue but the problem isn’t you need to add delay - you need to remove it! Which Bluetooth can’t have negative delay.
