Headliner fraying edge - How was it addressed?
Discussion in 'Model S: Interior & Exterior' started by scaesare, May 27, 2013.
  1. scaesare
    scaesare Well-Known Member
    NoVA
    My new MS has a bare exposed headliner edge at the driver's side door. This similar issue has been noted for other folks...
    My question is: hpw was this addressed? It appears that the headliner is trimmed too short to be wrapped/tucked up under the trim at that location, as it appears it should be. Did Tesla replace the entire headliner, or just attempt to fix that one area, perhaps using adhesive of some sort?
    Thanks.
  2. scriptacus
    scriptacus Member
    Los Angeles, CA
    I thought the exact same thing just yesterday. This might be a different issue, but the edge of the headliner was visible in a few spots right where it meets the rubber (foam?) seal on the mid and upper A pillar. Upon closer examination it turned out that the actual issue was that the seal had gotten tucked beneath the edge of the headliner. To fix it I put my finger under the seal, pulling it out about 1/2 an inch, and ran it the entire length of the window. This untucked the seal from beneath the headliner in the few spots where that had happened and evened everything out.
  3. scaesare
    NoVA
    Hmm, I'll check that out, thanks scriptacus.
    Forgot to attach the photo of my issue:
  4. scaesare
    NoVA
    So, update on this. I tucked the liner back under the seal as you suggested scriptacus, only to have it work it's way back out by the next day.
    So, I've called my Svc Ctr about it, and they sad they could take a look and see if the seal is too short, but he doubts it. They've seen this a number of times, and there's not much they can do about it. He thinks the factory may be trying to address it.
    But for now it feels like he's is suggesting there may not be much else to do other than live with it.
    Has anybody else had this successfully addressed?
  5. jeffaa
    jeffaa Member
    United States
    The other day I noticed my liner's edge sticking out in that same spot, but all I had to do was pull the seal back over. I'll check it again today.
  6. hans
    hans P631
    Menlo Park
    Mine does this all the time. I just keep pulling the seal back over. I asked the service center to look at it today since the car is in the shop anyway for something else. With see what they say.
    Before tuck
    After tuck
  7. digitaltim
    digitaltim Sig737 VIN628
    MD, USA
    Ditto for me - this is just poor design at the doors but tolerable except when my OCD kicks in and I have to stop the car to check all four doors.
  8. scaesare
    NoVA
    So I had the Service center look at this yesterday... he said he's seen others do this too.
    He said he used some velcro to hold the headliner "up" towards the roof a bit, and then made sure the A-pillar cover was as snug as possible, which helps hold the headliner up and under the seal.
    We'll see how it holds.
  9. digitaltim
    MD, USA
    It isn't the headliner as much as the rubber seal on the frame of the doorway...
  10. landover
    landover Member
    Pleasant Prairie, WI
    Has anyone have this completly resolved yet? My car has done this sense day one.
  11. UberEV1
    UberEV1 Member
    San Jose, CA
    I brought up the same issue on mine a year and a half ago, and sorry to report that Tesla won't fix it. I also agree it is a design flaw that could easily be resolved by having the subsupplier wrap the fabric around the backer board. Has this problem been seen on cars built this year?
  12. pgiralt
    pgiralt Supporting Member
    Cary, NC
    I've had this problem since day one as well and complained about it multiple times, especially after I drove a newer VIN where the headliner is now much longer so the rubber seal covers the headliner by quite a bit. I suspect all autopilot hardware cars no longer have this problem because they redesigned the headliner to accommodate the autopilot camera hardware.
    Sadly this his is the only unresolved issue with my car, but it bugs me to have to be flipping that seal back over the headliner on an almost daily basis.
  13. Cyclone
    Cyclone Cyclonic Member ((.oO))
    Charlotte, NC
  14. pgiralt
    Cary, NC
  15. Kbsilver
    Kbsilver Member
    Central NJ
    I'm not an automotive engineer (however I did stay in a Holiday Inn once), but it seems as the headliner just needs to be made 1/2" wider to stay tucked under the door seal.
  16. pgiralt
    Cary, NC
    Yes - that's exactly right. The P85D loaner I had was at least 1/4" longer than my 2013 build. Looks like maybe that wasn't enough.
  17. scaesare
    NoVA
    #17 scaesare, Jun 5, 2015
    I'm the OP... I didn't realize I had never come back to this thread to update it: I actually had my headliner replaced under warranty to address this about a year ago.
    Oh, and incidentally, that required removing the front windshield...
  18. pgiralt
    Cary, NC
    That's encouraging. At my last visit I mentioned it again and they were trying to escalate it to see if they could get mine replaced as well. Good to know that there is at least a precedent for doing it.
