Headrest settings not saving v.17.11.10
Has anyone adjusted their front headrests, saved the headrest position, but find it doesn't actually save?
After updating to 17.11.10, I've adjusted the front headrests and saved the settings. Usually it'll save that headrest setting for the rest of the day. But the following morning when I get back into the car, the headrest is always back to its full upright default position, and didn't save where I had set it.
Anyone else notice this?
Stupid question, but are you sure it's picking up/have you selected your profile from the screen when you get back in? There was an issue with profiles not getting 'set' on entry sometimes....
That would separate saving it to your profile from setting the profile at all.
The "set on entry" as you mention, might not be working for me. I've FOB opened the driver door to trigger the "set on entry", no luck.
BUT when I select my profile manually on screen, the headrest and everything has remembered the saved setup just fine.
Yea it's definitely picking up my profile as all my other settings are there, including lumbar support settings being saved. But from one day to the next, the headrest settings go back to default.
Also looked in the profile settings that the following items are saved and maybe headrest hasn't been programmed or added to the list yet.
Not a big deal but worth reporting the bug since it obviously asks you to save to profile after you set the headrest but doesn't seem to save.
Interesting: So if you set all kinds of wrong seat/mirror/headrest settings and DO NOT SAVE. Then leave the car and do a FOB entry somehow with any door or trunk/frunk click, then enter your seat. All my settings do not set to my profile, but once I manually restore, they are good including headrest. I'm wondering if headrest remembering is OK, but profile is not, when FOB defines it.
discovered the headrest IS saving to my profile, but somehow when I get into the car each day, all other profile settings are intact except for the headrest. If I move a side view mirror or lumbar support and the screen asks to "Restore" to my profile settings, by hitting Restore, that moves the headrest back to where I had previously saved it.
Not sure if I'm missing something else here...b/c all other profile settings remain intact (seats/mirrors/lumbar, etc except headrest). Again not a big deal but just a nuisance.
IIRC it comes up as a pop-up (if your seats support it) when you adjust the lumbar support using the buttons in the side of the seat.
Okay, I moved both the driver's and passenger seats, every which way possible, and I'm getting nothing on the main screen for adjusting headrest or lumbar. I even did a main screen reboot and it didn't help. Anyone else have any suggestions? TIA
Are you on 17.11.10? Just by adjusting the lumbar, you should see a pop-up on the screen asking if you want to adjust the headrest or lumbar
Reactions: vandacca
@kewina178: My X is behaving exactly like yours: after I manually adjust the headrest setting and click "save" on my profile, that setting is remembered temporarily, until I power off. When I return, the headrest setting returns to the original setting, not the manual setting. Clicking "restore" does not solve the problem.
This is clearly a bug that needs to get fixed. The headrest setting is not part of the user profile settings.
Make sure you report this to Tesla. These bugs won't get fixed if they don't know about it.
While overnite, my headrest does migrate to "all up position", but restoring my profile anytime, always remembers my saved head rest height and everything else I think.
Sensing FOB and restoring it's paired profile seems not to be working for me.
|v8.1(17.11.10)| AP2 |
Hi
I have the same issue with my MS. Did you find a solution to this?
