Headroom Question
Discussion in 'Roadster 2008-2012' started by Pantera Dude, Mar 18, 2012.
Tags:
  1. Pantera Dude
    Pantera Dude Member
    Long Beach, California
    I am 6'2" and about 175 lbs. Is the roadster likely to be big enough for me with a soft or hard top in place?
    Thanks
  2. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    There are owners up to 6'5" but that's probably at the upper limit. You'll be fine with the soft top or hard top at that height. Many taller people take the visors off which helps. They just slide off.
  3. NigelM
    NigelM Recovering Member
    Northern Virginia
    I agree. I'm 6'0" and have plenty of room with either top.
  4. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    It shouldn't matter for you, but you get a little bit more clearance with the soft top than the hard top. I only know this because I've driven the car with a helmet on (autocross) and I have a long torso for my height.
  5. Pantera Dude
    Pantera Dude Member
    Sounds good! Thanks guys.
  6. Dragon
    Dragon Member
    Italy
    I'm 6'3". No problems fitting into the car and no great visibility issues. It's a must to take the visors off, but I think everyone should do that. Leg room is no problem either.
  7. Bifff67
    Bifff67 Member
    Northern Virginia
    They just slide off? DOH! So i don't have to get the neck ache from ducking down to watch the stoplight? I love these forums, thanks everyone.
  8. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    At 6'3", no problem. You just drive looking over the top of the windshield like Mr Schwarzenegger, right?
  9. PV4EV
    PV4EV Supporting Member
    Area 51(a) / UK
    I'm about 6'2" and 225lbs … and much as I'd like to say that’s all muscle, its probably more doughnut related than working out. But even so I can slot right into a Roadster and the chassis hasn’t collapsed just yet !
    If, as your name implies, you can fit in an original Pantera you will definitely be ok in a Roadster. I've repeatedly tried to drive Pantera's but despite all my best origami efforts folding up my legs, I cannot get into any kind of safe driving position. So, all those DeTomaso posters I had on my bedroom wall as a kid turned out to be in vain …
  10. SByer
    SByer '08 #383
    Cupertino, CA
    Yup, and if you're careful, a bit of heat shrink tubing of the right size and a heat gun (and keeping the heat low and off of the windshield edges!!) can make the little pins disappear as well.
  11. Pantera Dude
    Pantera Dude Member
    Yes I've been a Pantera owner for almost 15 years and I do fit comfortalby but that is with dropped floor pans, without them, it was not acceptable for me though there are other taller guys than myself that do manage with the stock car.
    Thanks
