Not true anymore. Mitsubishi has air source heat pumps that work to -13F, and don't need backup heat.There is value in a heat pump. At reasonable outside temps, can heat at 3x the efficiency. Still need resistive backup of course.
Many heat pumps have a reversing valve rather than a reversible compressor.
The car will have to be disassembled, or listen for the compressor running when the heat is on but defrost is not.
Ok
here is the new disaster report
ac works great
but software boys must be the same as from windows 10.
took 5 minutes to switch from ac to heat. current draw from wall
24 amps because I left it plugged in to get these readings.
only on HI was heat ok.
confirmed Compressor running full blast on HI heat
feel the vibration in steering wheel and can also hear it ramp up
put my hand trough open left and right vents in front of car
on the little Radiators.
confirmed they were warm (total energy loss here
because they should have been cold if we had a
heat pump, Most of us already Knew that.
We need an emergency update for them to fix this
People in colder climates must really be suffering.
Major blunder here !!
Ok
ac works great
Pretty happy with the performance. On 6.2 it was resting many degree above the setpoint and it was annoying.
I wonder if this firmware has a separate calibration for the older sensor configurations that attempts to correct for this?
There was a running change shortly after I got my car (May '13) to add a "respirator" under the center armrest that draws cabin air in past a relocated temp sensor.
Earlier cars (like mine) apparently have the temp sensor somewhere else (steering column near dash?) and it seems to not perform well there, as I also find I have to offset my HVAC controls by ~4 degrees to get the temp I want.
I wondered that too. (Mine is also a "pre-aspirator" car). Seems almost everyone with the older sensor setups had this setpoint/actual discrepancy.
That is very possible, my Classic was built in Nov 2013 and has the aspirator under the headrest.
I assume you meant "arm"rest :smile: My March 2013 car does not have it there and I believe just has a non-aspirated sensor somewhere behind the dash near the steering wheel.
I guess there were a reason they made the change. I don't remember if you already mention it, but did you ever asked for the new sensor ? I don't know if they do replace it on request or not...
Something came to mind
it was 80 degrees outside with 70%
Humidity when I ran my test.
Is it possible that the car was making heat
and running the compressor to lower the humidity in the car?
So in essence, people are seeing that while they improved the cooling performance, Tesla hampered the heating performance. Perhaps the revised set point algorithms can determine if cooling or heating are needed and use 7.0-style cooling and 6.2-style heating as appropriate?
It looks a bit more complicated than that because 7.0-style heating works great on my car. And its getting colder and colder outside over here, at or near freezing point outside.
