Rumors says cars made starting Tomorrow... will see if it’s true.
See my post above.Rumors says cars made starting Tomorrow... will see if it’s true.
from the barWhere is that rumor coming from? Anything else changing with tomorrow's build?
Does anyone know if model 3 has a heat pump like the model Y???
if they start adding is this something that can be retrofitted or not
How much more range on average do you get with this change?
In California not much.
Believe it really only helps in the colder climates
I expect it could be retrofitted. It will probably take several thousand dollars of parts and a bunch of man hours to do it.
