Heater problem?
Discussion in 'Roadster: Technical' started by PokerBroker, Jan 4, 2015.
  1. PokerBroker
    PokerBroker Member
    Minneapolis, MN
    This is my first Minnesota winter in my Roadster and I'm not sure if my heat is working properly. It was -2 degrees today for an hour long drive I had and the car felt like it never got above 40 inside the cabin (thank god for heated seats). Usually when I use the heat I can only leave it on for a few minutes at a time until it is absolutely roasting inside. Would this cold weather affect the heater so significantly? Is it possible there is a problem? What do you other cold weather Roadster owners experience? And yes I had the top on ;) the hardtop.
  2. wiztecy
    wiztecy Active Member
    #2 wiztecy, Jan 4, 2015
    2.x's have a better HVAC system which gives off better heat/ac. My 1.5, even though its 56 degrees out feels like its blowing cold more than heat since the fan is pushing air which makes it feel colder. Dress warmly is the only tip I have and I also give much thanks to the very appreciated heated seats!
    Curious if the heater would work better if the HVAC was freshly charged.
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    No. Roadster only has resistive heaters. My 2.0 isn't that bad, but it's not overwhelmingly powerful either.
  4. Jaff
    Jaff Active Member
    Grimsby, Canada
    Wow PB, now I am wondering if my Roadster heater is working...I have never heard the words "roasting" and "Roadster heater" used in the same sentence before...:wink:
    I have found the hard top helps, but your feet still freeze...
  5. Curt
    Curt Roadster Signature #55
    Rockville, MD
    I have to agree with PokerBroker.
    Even in the dead of Winter, I can only run the heater in my 1.5 for a few minutes at a time. It gets hot pretty fast. I always have the hard top on in the Winter.
  6. tvuolo
    tvuolo Supporting Member
    Colorado
    I took mine out in -6ºF the other day. I found the heater quite good for everything but my feet. I saw a thread once about covering (or partially covering) the passenger foot vent to redirect more heat to the driver footwell. But for some reason I can't find it. Does anyone have that thread link handy?
  7. PokerBroker
    PokerBroker Member
    Minneapolis, MN
    My wife would kill me if I did that (if she found out lol)
  8. hcsharp
    hcsharp Active Member
    Vermont
    You must have a 1.5. Did you try turning on recirculate? That makes a big difference.
    A year and a half ago I insulated my foot-wells and behind the seats as part of a sound-proofing exercise. It made a noticeable difference keeping my feet warm.
  9. PokerBroker
    PokerBroker Member
    Minneapolis, MN
    I do have a 1.5 and I always use recirculate. I'm probably going to wait until it warms back up to 30 or so to see if I get my toastiness back or if I have a problem.
  10. djp
    djp Roadster 2.0 VIN939
    Toronto, Canada
    Here are the threads on re-directing the passenger side footwell heat to the driver's side:
    Living with a Tesla Roadster - Page 2
    Winter Performance
    Tesla used to sell an upgrade that did exactly this, but blocking the passenger vent with a small piece of foam works just as well for zero cost.
    @PokerBroker, I'd get your heater checked out. It's a simple electric resistive heater - mine gets quite toasty if it's on full blast.
  11. wiztecy
  12. PokerBroker
    PokerBroker Member
    Minneapolis, MN
    I'm currently running an experiment per Tesla Service Minneapolis... I was told that in extreme low temperatures the Roadster opts to use the heater to manage battery temperature at the expense of the passenger compartment. I currently have my car on in the garage (41F) with the heater blasting to see if it will work. TBD
  13. PokerBroker
    PokerBroker Member
    Minneapolis, MN
    Well, sure enough, piping hot within minutes... Now the fun part will be determining the temperature that initiates the change from heating the cabin to heating the battery. I hope the exhaust fumes don't kill me... Oh wait
  14. wiztecy
    If you have access to the diags screen you can see if the pump is running 100% as well as the heater. When I start the heater, it starts off low around 75% then reaches 100% capacity. I thought there's a different heating element for the pack, possibly they don't want to draw too much from the ESS at one time.
  15. thefortunes
    thefortunes Member
    Wisconsin
    I drove my normal commute (54 miles at 65-70mph) to the office today in -6F.
    Ran the heater on low the entire time and was comfortable (with seat heater on). I could certainly feel some coolness down around my toes, however.
  16. PokerBroker
    PokerBroker Member
    Minneapolis, MN
    The different heating element for the pack only works when the car is plugged in.
  17. sethr
    sethr CPO Roadster #1089
    Fairfax, VA
    During the polar vortex last winter, I went to visit a friend, and left my Roadster sitting unplugged outside for a few hours. When I started on my return home, the VDS indicated the battery was heating as I drove. (Regeneration was disabled during battery heating.) The cabin heat was also working. Interestingly, even though battery heating ceased and regeneration came back on during my trip home, when I plugged in to charge, battery heating came on again, and charging did not start until the battery reached a satisfactory temperature.
  18. Doug_G
    Ottawa, Canada
    This is wrong. Its the cooling that is shared, NOT the heating.
  19. hcsharp
    Vermont
    +1. The pack heater heats the battery coolant. The cabin heater heats the air with no heat exchanger from coolant to air. At least that's how my 2.5 works.
  20. PokerBroker
    PokerBroker Member
    Minneapolis, MN
    The previous posted Tesla blog link about heating and cooling confirms that the separate pack heating element only functions when the car is plugged in. I'm not sure about my SC's claim that the cabin heater diverts to the battery if necessary during driving but it would explain why my heat didn't work at -2F but did at 41F.
    The blog is 2006 so there is certainly room for it to have been changed either before or after 1.5.
