As I understand it, in addition to the heat pump there is a heat exchanger wherein excess heat from the drivetrain may be routed to the cabin--although I'm not 100% sure of this.
Can the heater be turned on while the car is charging?
As @ChadS said, yes. This will be easy to do once the smartphone app is released later this month.Can the heater be turned on while the car is charging? I'm thinking ahead to the iPhone App---turn the heater on, I'll get to the car in 5 mins after it's nice and toasty.
Prior thread that might provide some more informationCan someone tell me the following:
1. How does the heater system work
2. How long will it take (on average) to heat the vehicle to 72 F if it is say 20 deg outside
3. How much energy will it use
Thx, M
Yes, I think there are some climate control bugs out there which will be fixed in a near-future update.
I've been driving in the range mode, which reduces energy to the heater and uses the seat heaters. Seems to work fine for me. I had one morning drive last week where it was 7f. That day I set to normal mode, as it was simply too cold in the car. The battery gave me all sorts of warnings about warming itself that day.
When I went out to the car ten hours later it warmed up amazingly fast. I was impressed.
MDS,
1. The heater is a heat pump. ....
Todd, Do you have a source for this? My contact at Tesla told me (as is stated in the previous thread pointed to by Evan) that it was not a heat pump but a simple resistive element.
