Heating system Model S
Milzit
10
0
Oslo, Norway
Hello
I´m living in Norway and we are considering to make a reservation for Model S. Do anybody have any information about the heating system or is that not ready yet? In a country like Norway you need heating in the winter.. It will just take the power from the battery?
Cobos
S60 Owner since 2013 - sold, S85D owner since 2017
Jun 22, 2007
1,501
2,044
Oslo, Norway
The Roadster uses electric heating and not a heatpump. That takes a bit of a bite out of the battery, so I hope they go with a heatpump system for the Model S. I also want a Webasto like diesel/oilbased heating system for cold climates, but I'm not sure if I'm getting that.
Cobos
jkirkebo
Model S P85+ VIN 14420 EU
Jun 13, 2010
961
12
Fredrikstad, Norway
There should be no need for a Webasto (or similar) if they use a heatpump. 1.5kW for heating will give you a ~10% loss in mileage which for me at least is very acceptable. And I also live in Norway ;)
The newer heatpumps give good performance down to -20C and works down to -26C. There should of course be a resistance heater as backup.
eledille
TMS 85 owner :)
Jan 13, 2010
535
6
Oslo, Norway
Some of us need to cross the mountains in the winter. That sometimes means waiting for snow clearing equipment for hours in very low temperatures and high winds, so I certainly want a diesel heater. The lack of a diesel heater as an option is not a total showstopper, as one can be installed later on. But a factory installed unit would obviously be better and probably less expensive too.
I think they should go for a heat pump as standard and an additional diesel heater as an option. Burning off the power in a resistor is just silly when you can get at least three times as much heat for your electrons with a heat pump. Besides, air cooled resistance heaters burn dust. You want a water cooled unit, but that will probably cost more than a heat pump, as only minor modifications of the AC unit are needed (a few computer controlled valves and a reversible pump).
PaulM
107
0
Ottawa, Canada
I too have thought about the benefits of a fuel powered heater (gets cold in Canada). Some old VW Beetles had a gas heater since you didn't get much heat from the air cooled engine. Although I have not found one yet, a Webasto type heater which could run on a small propane tank (like the ones used for camping) would be ideal. Coleman makes a propane water heater for camping so it should be pretty easy to do (http://www.coleman.com/coleman/colemancom/detail.asp?product_id=2300B700).
However as jkirkebo indicated above, the new heat pumps have much better performance than in the past, the only problem is I don't think there are any suppliers building heat pumps in the automotive industry, only residential. Remember, 99.999% of current vehicles have more than enough waste heat to heat the cabin so why would anyone bother developing a heat pump, only a straight A/C is required. Tesla would have to design their own and I think they have enough on their plate already. GM designed a heat pump for the EV1 but they also spent a billion dollars on its development. Even Nissan went with resistive heater for the Leaf. (KISS)
I am told that a heat pump is simply an A/C running backwards so Tesla may be able to get an A/C supplier to modify their A/C unit to enable running as a heat pump but I don't know how efficient it would be. I am certain that all EV manufacturers will eventually go this route, I just don't know if it will be in the Model S version 1.0.
Another thing to consider is that the Model S motor will be liquid cooled and even if it is about 90% efficient, it will still generate quite a bit of heat. Having a heat pump extract heat from the coolant instead of from the air would be much more efficient.
eledille
TMS 85 owner :)
Jan 13, 2010
535
6
Oslo, Norway
Why propane? We have a diesel powered Webasto Air Top 2000 unit in our Think City which works just nicely. The same unit is available in gasoline, biodiesel and ethanol versions. It uses between 0.2 and 0.4 liters per hour and generates 1 to 2kW of heat. The difficulty is where to place the fuel filler neck and exhaust pipe. Think solved that by placing the tank and filler assembly behind the rear license plate, which is tilted upwards to get at the filler cap. If you plan to have the tank and filler inside the car I can understand the concern (diesel is messy), but then I think ethanol would be OK.
To get maximum efficiency from a combined A/C and heat pump unit, it needs a computer controlled choke valve that separates the high and low pressure parts of the system, a pump that will work in both directions, and a pump motor drive capable of many power levels in both directions. This is now less expensive than it used to be. Modifying an automotive A/C design to do this might be expensive, but then the Model S is a high end car, the "reduced range in cold weather"-argument shows up quite often, and the Model S will be made in much higher numbers than the roadster, though fewer than the Leaf. I don't know how it all adds up, but I hope for the best.
Toyota had a heat pump in their RAV4 EV, I believe, so Toyota has done it before. Anyway, as so many new electric vehicles are going to hit the roads in the next few years, I would have thought that some supplier would be interested in doing this.
If they end up with a resistive heater, then they really need to offer a fuel-powered unit.
I agree about extracting waste heat from the motor, but I think that that might be a bit challenging. If the battery, pem and motor are on the same cooling circuit they will need to make sure that the heat pump does not negatively affect the temperature of the battery. They might need sensors, multi-way valves and firmware to control the whole thing.
araxara
S-P85#3,218 X-LR M3AWD
May 11, 2012
1,012
380
Tucson, AZ
Now that some people actually have a Model S, I would think there would be more information available regarding the type of heating system used in the car. I can't find any information online. Maybe some here knows? If the Model S uses a heat pump, I would think that Tesla would like to advertise this. But their silence is starting to worry me.
araxara
May 11, 2012
1,012
380
Tucson, AZ
I've been told it's a resistive heater, which I found disappointing. I hope it's actually a heat pump.
I hope it's a heat pump too because if the resistive heat in the Nissan Leaf is any indication, winter range will get zapped considerably. From what I've heard, running modern refrigeration systems backwards to make them into heat pumps is not an issue.
NigelM
Recovering Member
Apr 3, 2011
13,386
555
Northern Virginia
Dude, you live in Tucson. This shouldn't worry you for one second.
jerry33
Mar 8, 2012
19,516
21,710
Texas
It's primarily a heat pump, but I believe there are also resistive heaters for extreme conditions. My understanding is that heat pumps aren't great when the temperatures are very cold (below 0 F). If you get the leather seating option, there are seat heaters. I don't know why they don't come with the cloth seats, because heated seats are very efficient (mainly because they let you set the main heating at lower temperatures or not use it at all.)
araxara
May 11, 2012
1,012
380
Tucson, AZ
It gets cold in Tucson in the winter time and we occasionally have snow. But I'm planning to travel to the White Mountains where it's properly cold (similar to New England). It's a 200 mile trip with a about a 4500ft elevation gain.
araxara
May 11, 2012
1,012
380
Tucson, AZ
That would worry me much more than the weather.
Yes, it's pretty close without the weather. I've used several "programs" to estimate if I can make it. The most complete I've found has been Green Race (http://jurassictest.ch/GR/).
mknox
10,103
1,866
Toronto, ON
A while back at one of the Beta showings, I asked the Tesla rep about this. I asked if they recovered heat from the battery/motor cooling system and was told "yes" they do. We didn't get any more technical than that other than for the rep to say Tesla was really trying to squeeze as much eficiency out of the system as possible and they didn't want to throw otherwise usable heat "overboard" when it could be used for cabin heating.
KBF
Model X owner (formerly Cdn Signature Model S)
Jun 26, 2009
557
2
Steinbach, MB, Canada
:wink: I suppose it's all relative. While I haven't heard the term 'properly cold' before, IMO that would be if it goes down so low it doesn't matter if you're reading Fahrenheit or Celsius... So cold it doesn't snow much. If you ask some of the Canadian posters here that own Roadsters, the cold has a minor effect on range, and speed is way more important (and wind as well). I recall a Tesla rep saying that extreme heat is worse than extreme cold.
Mar 30, 2010
461
2,576
My heatpump for my house is speced at 2:1 even at -20 degress C. So even at temps that low it's still twice as efficent as using pure electricity. It's a matter of cooling fluid and pressure.
