I'm panicking a bit here. I always keep my car plugged into 120v outlet, using what I assume is the yellow cable that came with the car. As it generally takes care of itself, it is always charged when I get in. Not today.
Haven't used it in a couple weeks or so. Got in it today and it says it is down to 14km range and it won't charge. The charging cable is plugged in and the lights on the charger door area are steady blue. But is says "connect power cable" and the red power plug light is on on the dash. I tried using the other cable arrangement I have, plugged into my dryer outlet and the same thing; blue light on, but it says "connect power cable".
Help. What do I check?
thank you,
Rick
thank you,
Rick
