I think you were also asking how to use the adapter. One end fits the Tesla, the other end fits the charger, then it just works. Only caveat is that you probably shouldn't unplug the charger during a charge (I'm not certain this is written, and I should imagine there are safeties in place for an event where it may occur even if it is written). The adapter technically makes it possible to easily disconnect during charging, because the Tesla can only lock the adapter in place, so you need to know that you can stop the charge from MCU or app before unplugging. I think J1772 may include a locking mechanism with which you can use your own lock. This would allow you to lock the charger to the adapter and reduce the likelihood of a third party unplugging it during a charge.
If you were to try to use the adapter and find yourself unable to charge, a guide on how to use the given non-tesla charger may be necessary, but that would likely be better found outside of this forum.
