Help! Credit card slid behind center console
phillipj06
New Member
Sep 3, 2019
Hello!
My credit card was siting on the sliding cover of my center console in my 2019 Model X. The cover got opened and the card went in with the cover, now I cannot get the cover to stay open and my card is stuck inside. What can I do?
Reactions: Jimmy 1
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,334
4,461
Kaneohe, HI
Oh my, the dreaded disappearing sock trick has struck again.
There is a technique that some people have used. They partly open the door then press down pushing it from its snap in mounts.
Then reaching up and snag the card. Look at the door's relative position so you know about where the snaps are to place it before you reach under and fit/push it back up and into its original position.
Before you try this, please search the forum more or search Youtube and locate a clear description of how. But that's the basics as I recall it described.
dstasse
42
9
NJ
Same thing happened to me, only it was the local electrical inspector's sign off certificate for my wall connector. Searched you tube, could not find our console. Started to remove entire console by removing the two bolts under the rubber mat. Was still held in securely in the rear which I could not access. Asked the tech at my local dealer. He suggested calling mobile service. Haven't done that yet.
Akikiki
A'-Lo-HA ! y'all
Nov 26, 2012
6,334
4,461
Kaneohe, HI
I have a '17 S. I can reach forward inside my console all the way to the front. I've even found a small square hole on the upper left side where I have threaded wires through into the console for power. I accessed the outside of the console by removing the cubby and reaching in. You can try that before you call anyone.
In the back seat, the back center panel of the console can be pulled out to access the inside of the console.
