Help Evaluating Battery Analysis
I am looking at a used Tesla, model S. 2012, 85, RWD. It has 202,000 miles. Yes I know that is very high :)
I paid the owner to take it to Tesla for a pre-purchase inspection and they looked at a lot of the basics (no major red flags) and then he had them do a battery analysis so I can gauge the current battery degradation. He provided it to me but it doesn’t mean much to me. I guess Im surprised this can’t be distilled down to a cycle count or battery percentage.
Could someone help in understanding it? The car is being offered at a pretty good price so I am just trying to figure out if the battery is good/bad/okay and what I can expect for longevity. Thanks in advance!
HV Battery Capacity Retention Warranty Check
Vehicle was sold without a HV battery capacity retention warranty.
CAC Fleet Check
The HV battery installed within 5YJSA1DN3CFP02451 has a Calculated Amphour Capacity (CAC) of 190 Ah. This is 4.1 % lower than the average of similar vehicles, which is 198.1 Ah.
This VIN's CAC value is within an acceptable range when compared to its similarly aged fleet. For more information, see Article 5404. Note that CAC data can be inaccurate in certain usage patterns.
The number of drives detected between the selected timestamps was 7.
The average distance per drive was 8.8 miles.
The longest Drive session found between the selected timestamps was 2024-05-05 21:00:48 UTC until 2024-05-05 21:35:36 UTC. The following analysis is based on that event.
Range & Energy used
The vehicle was in Drive for 0.6 hours / 35 minutes.
During this time it travelled 30.0 miles showing a use of 17% displayed SOC, 8.7 kWh and 289 Wh/mi.
Rated range used was 34 miles, it dropped 13% more than distance actually driven.
Driving Statistics
The maximum speed reached during the journey was 96.8 mph.
- The proportion of Drive time spent above 70 mph was 40.8% (14.2 mins).
- The proportion above 80 mph was 18.7% (6.5 mins).
- The proportion above 90 mph was 0.9% (0.3 mins).
The accelerator was pushed aggressively 8 times.
HVAC consumption
HV HVAC used 0.14 kWh which is 1.6% of the total Drive energy, 0.5 miles Rated range or around 4.6 Wh/mi.
Of this, the A/C compressor used 0.14 kWh (1.6%), Cabin Heating used 0.0 kWh (0.0%) and Battery Heating used 0.0 kWh (0.0%).
The average left cabin temperature setpoint was 71.6 degF, the average right temperature setpoint was 71.6 degF.
The coldest ambient temperature was 67.1 degF, the hottest ambient temperature during Drive was 77.0 degF.
The coldest battery temperature was 58.1 degF, the hottest battery temperature was 92.3 degF.
Range Mode was NOT used.
Low Voltage System consumption
The low voltage system (via the DCDC) used 0.25 kWh which is 2.8% of the total Drive energy, 1.0 miles Rated range or around 8.2 Wh/mi.
CAC Fleet Check
Range & Energy used
Driving Statistics
HVAC consumption
It's good according to the report.
This report doesn't have any options to predict any future performance or longevity.
It's just like the tire pressure is good now but it doesn't tell whether the air is leaking or you'll get a flat tomorrow.
Reactions: Cheburashka
Upvote 0
This is what I am asking, either the car is lying, my math is wrong, or the battery is wrong.
A better way of asking this: your model y has a 75k kwh battery. Do you get 215 miles when you charge to 100% and drop to 0 (or 129 from 80 to 20)?
I use Tessie to show me the battery stats. My X has a 90 battery which is actually 84.6kWh new... But shows a current total capacity of 70 kWh. When I charge to 100%, Tesla's own stats show 216 miles as the full range.... BUT the ACTUAL real world is more like 175 miles, and that would be to ZERO. Don't go to zero, there IS NOTHING BELOW THERE. You WILL end up on the back of a tow truck.
Don't base your travel on the claimed miles at the start. The computer will continuously adapt the range and show you what you have left from that point, but as it will usually use more than the computer is predicting - especially in a headwind or in hills or highway speed.... The number should be understood to be around 10-15% HIGHER THAN YOU WILL ACTUALLY GET.
Use the nav on a trip and do what it says, it will direct you to superchargers with between 10% and 20% arrival range remaining for the fastest charging.
I'm in Phoenix right now after driving cross country (again) with my X, and towing the whole way. Already been to San Diego, and going back there in a couple days. Lots of supercharging visits. LOTS of headwinds. I don't trust the mileage guesstimator, because it uses Elon lie-o-tron math. When towing into a headwind, my 100%-to-0% range is NO MORE than 120 miles. That's not good, and the computer will still try to tell me I can go 160 miles. Not happening in this lifetime.
Upvote 0
