Help identify this outlet
Discussion in 'Supercharging & Charging Infrastructure' started by IceAge, Jul 2, 2018.
  1. IceAge
    IceAge Member
    United States
    A friend wants to know if there's any way to charge off of this outlet. Sorry I don't have a better picture, but it looks like a twist lock, with 2 of the 3 receptacles having a locking blade. There is an odd male pin coming off of the center. I know Tesla makes a 10-30 and 14-30 adapter for the UMC cable. If this outlet could be identified, perhaps an adapter to one of those could be found?
    Thank you for any guidance you may be able to provide!
  2. P85_DA
    P85_DA Supporting Member
  3. Ray305
    Ray305 New Member
    South Florida
    I think that's a 3 phase twist lock and the center pin is ground. This guide might help if you can look closer. This won't be a standard adapter. But if it's 277/480, an electrician should be able to use a hot and neutral to give you a good 277 volt source. If it's 120/208, you can wire two hots for 208 volts. But this will need more research and someone who can wire a custom plug.
  4. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
  5. IceAge
    IceAge Member
    United States
  6. AlexanderAF
    AlexanderAF Member
    Montgomery, Alabama
    Not sure I’d want to put my thing in that..
  7. WinjesFarm
    WinjesFarm Member
    45875 County Road One, Lake City, CA 96115
    Perhaps this chart will help
  8. eprosenx
    eprosenx Active Member
    Beaverton, OR
    A better picture I think is required to provide good feedback - I am not sure we have correctly positively identified this receptacle type yet. Also, can you get a picture of the breaker that feeds it?
    It is likely that you could find a way to charge off of this safely with an adapter.
    It is hard to tell if it is three phase with no neutral but just a ground, or if it is single phase (hot hot neutral, plus ground).
    If it is 277v you can't use it with a Model 3 from what I understand. The UMC for sure is not rated for that. The HPWC's are, but they are not plug in and the Model 3 I don't think will charge from them at that high voltage.
    Any idea what this receptacle was intended for?
