Hello, I will be bringing my car in to an independent mechanic to diagnose a noise behind my dash, which occurs when I first get into my car and the car is still off, with nothing running (no climate control). This noise runs for about 10 seconds, then stops. Based upon my research from this forum, I think it's likely an HVAC actuator that's making the noise. However, many of the previous posts on this topic have deleted their video recordings of their original noises. So I'm hoping that someone who has experienced this type of issue could take a listen and give me your best educated guess as to which actuator might be involved.
Since I will not be taking this problem to a Tesla SC, I will be bringing all 5 HVAC actuator parts for potential replacement. It would be nice if I had a bit of a clue as to the most likely actuator that might need to get looked at, because some are easier to get to than others.
Another possible clue is that my AC doesn't seem to be blowing the air strongly enough - the air temperature coming out is cool enough, but the airflow is a bit weak.
Thanks in advance for taking a listen!
