HELP! I'm stuck in a snow storm
Discussion in 'Model S: Battery & Charging' started by ⚡️ELECTROMAN⚡️, Dec 14, 2016.
  1. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ Fritterer and waster of hours in an off hand wayer
    Portland, Oregon
    How many miles of charge does running the heater use. I'm stuck in Lake Oswego Oregon and can't get home. All traffic has come to a very slow crawl. I may have to sleep in my car. I have 100 miles of range left. Day #3 with my new car
  2. SW2Fiddler
    SW2Fiddler Bannd Member
    Houston TX
    Seat heat uses much less than the heater, I am told
  3. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    I would probably sleep in the back though. It's about 30° out and I would want to heat the car to the low 70s
  4. trils0n
    trils0n 2013 P85
    SF Bay Area
    Depends on how cold it is, what temp you have the interior set for, how long you run the heater, etc.
    How much distance until you get home?
    Worst case scenario: Running at full blast, it seems the heater uses around 6-8kW, so if you run it at full blast for 1hr, it will use 6-8kWh. Figure 3 miles per kWh and that will be 18-24 miles of range per hour at full power (it won't run at full power the whole time, unless it is so cold that the heater must run at full blast the whole time -- usually the car warms up and then the heater ramps down).
    Seat heaters are your friend. They will use much less energy, and help you stay warm. Keeping the interior in the low 70s will take quite a bit of power.
    • Informative x 3
  5. Yinn
    Yinn Member
    Behind you
    You want to use seat heaters, heated steering wheel etc. You do not want to use the actual heater to circulate hot air.
    I read an article on it, will try to dig it back up. Basically the heater for air uses a LOT of energy. The seat heaters, use a fraction of it and will keep you warm for much longer.
    Keep yourself warm and stay safe.
  6. Hank42
    Hank42 Member
    United States - NY
    +1 what trils0n said. As far as sleeping - you might be out of it sooner than you think according to the latest weather report.
  7. Yinn
    Yinn Member
    Behind you
  8. PRJIM
    PRJIM Member
    until you kill your 12v battery and have to replace it.
  9. Evbwcaer
    Evbwcaer Member
    Minnesota
    There are a lot of charging options on Plugshare in that area. Good luck
  10. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    I hope so. Just have to wait for all of the commuters to go away.
  11. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    IMG_1825.JPG Sounds like I don't want to run the heater all night unless the car's plugged in. Space car grounded.
  12. Pollux
    Pollux Active Member
    Merry land / District of Confusion
    Dunno exactly where you are in Lake Oswego but here are some charging options, courtesy of plugshare.com:
    Trolley lot,
    311 N State St, Lake Oswego‎ OR‎ 97034, United States
    3 120V plugs
    Shore power, in front of Shell gas station
    209 A Ave Lake Oswego, Oregon 97034
    4 120V plugs, claimed @ 20A
    Office Building
    500 1st St, Lake Oswego, OR, 97034
    Blink network chargers, 2 J1772, subject to Blink network fees
    Quite a few others are available, depending on where you are now and how difficult it is to reach them. Since you have internet access, try looking at plugshare.com.
    Good luck!
    Alan
    P.S. of the three I've cited, the Blink chargers -- if they work, if you can gain access to them -- are your speediest charging option.
    P.P.S. I'd've described the picture you sent as showing a "dusting" of snow. Is that amount really grinding traffic to a halt?! Wow.
  13. andrewket
    andrewket Well-Known Member
    Keep in mind that with 120V (even @20A), with the heater on full blast in that cold you'll be using energy faster then you're gaining. Of course it's better than nothing at all, but a 240V J1772 would be much better.
  14. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    Unfortunately I didn't pack my charging cord. I'm going to run a 15 minute experiment with my heat on high to see what happens to my range.
  15. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    Unfortunately I didn't get AWD because I heard Two wheel drive Teslas do great in the snow. But do they? Will I be good to go once most the other cars are off the road? I really don't want to mess up my dream car.
  16. S'toon
    S'toon Knows where his towel is
    SK
    Hmmm, I have a cousin who lives 1/2 an hour, 45 minutes from there.
  17. andrewket
    I really wouldn't do that. I drove through the midwest in single digit to sub-zero weather last year, and I made it through by using the seat warmers, the HVAC on sparingly, and a heated blanket plugged into the 12v.
  18. andrewket
    You don't need your mobile connector (UMC) if you find a J1772. You just need the J1772 adapter. Do you have that with you? You should always leave it in the car. If you're really desperate, look at plugshare. Find another Tesla owner. You might be surprised, but they'll likely let you charge at their house and give you a bed.
    • Like x 6
  19. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Not a good idea as you're wasting the range you may need to get home.
    The J1772 charging stations don't use your UMC, just the adapter which always stays in your car (it is in your car, right?)
    No hotels nearby?
  20. ⚡️ELECTROMAN⚡️
    Portland, Oregon
    Good advise.
    Experiment done. I'm warm now, but I lost about 4 miles of range. That shows how extraordinarily efficient the motor is.
