Correct, it did not have a NEMA 14-50 chord on it. It was just like the normal HPWC that you have to hard wire. I almost kept it but I didn't want to have to pay an electrician to run thicker (probably 2 gauge wire) wires and also buy a 100amp breaker when I already had 8 gauge wire ran inside the walls with a 50AMP breaker. I also charge at night so there was no reason for me to need the 80AMP version since I'm asleep when its charging anyway. I just like the way the HPWC mounts versus the one that comes with the Model 3.
When I contacted them, they apologized. They said they were all shipped together and from the outside of the box, you can't tell the difference. I bet they were shipped to them on accident. The small label on the box clearly states its 40AMP on it and the other one I got stated it was 80AMP so there was a clear difference in the small label. Someone at the factory probably screwed up.
Ah, just for reference, all HPWCs can do 80A (including the one you have now), the rotary switch sets the actual draw (40A in your case). Basically they take the stock version set switch 1 down, rotary to 8, and wire in a 14-50 plug. Guessing they forgot the switch change when they did the value add work.
