Chris TX
The way the PDF suggests is not what I do, and seems like a harder way of doing it.
I do this:
1) Unlock the car
2) Press j1772 button to stop charging and release the lock
3) Release j1772 button to have the handle attached to the j1772-tesla adapter
4) pull j1772. Adapter will come out with it.
5) Press and hold j1772 button
6) Release the adapter from the j1772.
The only problem is your #3. That would cause the pilot signal to reengage and the car would lock the adapter again.
Push the button on the j-plug, which unlocks the adapter from the car (as long as the car is unlocked)
Use second had to grab the adapter and pull both away from the car at the same time.
Remove adapter from j-plug
