American car mags include rollout (EU ones often do not)- and have clocked the AWD+ at 3.5 and the P at 3.0-3.1. Tesla lists 3.7 and 3.1 respectively though on the website.
Pre-AB same mags clocked the AWD at 3.9-4.0. Though Tesla still lists it on the website at 4.2, because unlike the P they do NOT use rollout for non-P car times.
That's the dishonest part.
Car mags measure both the same way- every other car company I'm aware of advertises using the same measurement for all their cars.
Only Tesla uses the "better looking" measurement for P, and the less-good-looking one for everything else.
This isn't new, folks have been complaining about this since they began doing it with the P85 years ago.
I just watched that earlier today and it's an excellent video. It also makes sense that as long as your brakes are powerful enough to lock up your wheels (necessitating ABS activation), then the limiting factor on braking performance is basically tire grip. If the tires on the P and non-P models were equal (they aren't from the factory), they'd probably brake exactly the same (at least the P and LR would since they weigh the same...SR+ would beat them, and it may already beat them in braking stock). As others have said, the advantage to bigger/performance brakes is that they can maintain performance longer under stress (ie, when driving on a track). There is no difference for road use. It's all in the tires.The guy on Engineering Explained on Youtube actually released a great video on Youtube today talking about Tesla and just this particular topic.
Here's the video that everyone should watch:
The SR would brake the same. This is an acceleration calculation. It takes mass into account. The force would be different but the accel is the same.I just watched that earlier today and it's an excellent video. It also makes sense that as long as your brakes are powerful enough to lock up your wheels (necessitating ABS activation), then the limiting factor on braking performance is basically tire grip. If the tires on the P and non-P models were equal (they aren't from the factory), they'd probably brake exactly the same (at least the P and LR would since they weigh the same...SR+ would beat them, and it may already beat them in braking stock). As others have said, the advantage to bigger/performance brakes is that they can maintain performance longer under stress (ie, when driving on a track). There is no difference for road use. It's all in the tires.
SR has the same wheels and brakes as the LR but it weighs less due to the smaller battery pack, so it should be able to stop more quickly.The SR would brake the same. This is an acceleration calculation. It takes mass into account. The force would be different but the accel is the same.
F = ma. The calculation goes around the acceleration (a). So the amount of force required to stop the vehicle is the same as the amount of force required to accelerate. Being lighter it requires less force and less energy to stop an SR than a LR but the whole argument around tires is independent from the mass of the vehicle. The tires are the constraining factor. So no, being lighter does not affect the acceleration/deceleration, only the amount of energy required to do so.SR has the same wheels and brakes as the LR but it weighs less due to the smaller battery pack, so it should be able to stop more quickly.
Time = (vf- vo)/a... implying a larger acceleration results in less time to stop.Assuming the tires\friction is the limiting factor, and is constant between the heavier and lighter car, the lighter car still would stop in a shorter distance because of exactly what you just said. The friction isn’t zero... the inertia you are overcoming is inherently less because of having less mass, so if the force is a constant between the two calculations you are still looking at a = F/m... a smaller denominator means greater acceleration (or deceleration) and the F is the sum of the forces.
Well that’s just it. Friction is NOT constant. Also the force in each case is different. The acceleration is the same which is why weight is not a factor. This cease to be true if you are skidding in which case the weight does play a role (lighter better). But under “ABS” braking, the tire quality is all that matters.Assuming the tires\friction is the limiting factor, and is constant between the heavier and lighter car, the lighter car still would stop in a shorter distance because of exactly what you just said. The friction isn’t zero... the inertia you are overcoming is inherently less because of having less mass, so if the force is a constant between the two calculations you are still looking at a = F/m... a smaller denominator means greater acceleration (or deceleration) and the F is the sum of the forces.
Re calculate the equation of motion. Look at the video. Weight is not a factor.Time = (vf- vo)/a... implying a larger acceleration results in less time to stop.
d = (initial velocity x time) + (at^2)/2.... so a smaller time means smaller displacement (distance) to stop.
That's super counterintuitive but yeah essentially, the "braking force" is proportional to the friction coefficient which varies linearly with mass so it cancels out. Disclosure: I am a Ph.D. in Physics.brain fart. The friction isn’t the same. The coefficient of friction is (the tire compound)... the friction itself is different because friction is in and of itself calculated on the basis of the normal force on the object; which is relative to its weight (mass x gravity; gravity being constant). Thus negating mass from the equation of displacement.
So, as I admittedly don’t know the variation of change (decrease it seems based on what I’m reading) of the coefficient of friction for standard air filled tires based on the load of the tires themselves, care to comment more?That's super counterintuitive but yeah essentially, the "braking force" is proportional to the friction coefficient which varies linearly with mass so it cancels out. Disclosure: I am a Ph.D. in Physics.
