ColoradoMike
We originally were going to go with a NEMA 14-50 outlet and then we decided on putting in a wall charger in our garage. My neighbor and did the installation and while the wall charger ran $200 more, for us it was worth it.
A wall connector in a box being better is your opinion with nothing to back it up and is not a proven solution. Does Tesla even recommend such an installation? Putting an electrical device in a box can sometimes cause issues, typically with overheating.A wall connector in a box (if you so choose) is even better.
Gasoline cars have been a proven solution to transportation. What did you go with there?
Why do you think Tesla dropped the 14-50 adapter. Then dropped the mobile connector. They are old school. It’s not to make $100 more. It’s because they are a much better solution. Less problems. Less melt downs. It’s a no brainer today especially where you now get credit towards the wall connector.
No GFCi, much better weather proof, wider range of charging, easier / cheaper to adjust, can be paired with more connectors, Wi-Fi access.
Actually, my 240V 30A connection for charging with my mobile cord cost me approx. $27. Everyone's situation is different, so I'm not saying everyone else can do the same... but I park in a detached building, let's call it a barn. I already had a 240V 30A circuit there to backfeed my electrical system with a portable generator during power outages, which happen a lot here. I just bought the appropriate receptacle and a little junction box, and wired it into that circuit. The mobile cord came with my Tesla. Been using that going on 5 years now, it charges at about a 20-22 mph rate. Incidentally, that circuit won't be getting used for the generator much longer.... got a Solar Roof and Powerwalls installed recently, heading toward production soon I hope...There are many advantages to wall connector, too many to list besides max charging. Cost is almost the same when you factor in a plug needs expensive GFCI breaker and you need to make sure you get one that doesn’t false trip. Labor and wire dominate the cost. Not the connector.
It’s even easier to just leave the mobile connector in the car. That’s why they call it “mobile”. You don’t even have to remember it or think about it.The mobile connector also has a big advantage in that it's easy to take with you when you go on a trip. You can charge up at EV parks with electrical connections or at family's or friend's house when you visit.
Personally, I find no advantage to faster home charging. I just charge while I'm sleeping, and there are few possible scenarios in which that isn't more than sufficient. Never had one occur yet. Before you get the car, you think of all the possibilities - I bought a J1722 connector, the multi-pack of adapters, etc.... and never use anything but the mobile cord that came with it at home with one 30A adapter, and Tesla chargers away from home.1st things 1st: Yes, I searched the for this topic before posting. I only found 1 in the Model Y section.
So, Should I go with the Full Monty wall charger for my Std Range Model 3 or for the basic 14-50 receptacle install? The panel is in my driveway furthe back and I'd want to put the connetion point (wall or receptical form pipe in the ground) closer up near the front for ease of access (24 or 20 foot cable). There's no incentives for eithe since my utility, LADWP, doesn't include the Tesla wall charger in it's list of authorized units. They say they can't connect to it to monitor it.
So, I read that the mobile charger supplies 32a only but I also read the std range RWD can only take 32a. All that considered, I'm leaning toward the receptacle.
So you just increased the cost of selling your old home by $425. While having a high amperage 240 volt circuit in the garage to charge EVs is a plus, and becoming more of a plus, having a 60 versus 50 amp circuit won't make much difference to buyers. What will probably make a difference in the future is having a 100 amp circuit for EV charging. For a Ford Lighting, Hummer EV, probably for the new Cybertruck, and other vehicles with larger batteries, being able to charge at up to 80 amps can make a significant difference.Valid point. If you think 14-50 is a bigger seller than swap a 14-50 in when you list it and take your wall connector with you.
I know several folks with EV’s. None with a welder or RV. I recently sold a house with a wall connector and buyer explicitly called out that wall connector be included. He owned the same Model X.
Tesla dropped including 14-50 with new cars a while ago.A wall connector in a box being better is your opinion with nothing to back it up and is not a proven solution. Does Tesla even recommend such an installation? Putting an electrical device in a box can sometimes cause issues, typically with overheating.
Tesla hasn't dropped the 14-50 adapter or the mobile connector. They are not old school; they are just a different way to charge your Tesla.
I have no idea why you think a wall connector is "easier / cheaper to adjust, can be paired with more connectors". That is simply not true. As for Wi-Fi access, why is that necessary or helpful with a Tesla? The car will tell you what it's doing charging wise. The fact that a mobile connector should have a GFCI breaker versus a regular breaker for a wall connector is the only valid point you're making here.
Ooh wow, that will break the bank. I wouldn’t waste the time myself.So you just increased the cost of selling your old home by $425. While having a high amperage 240 volt circuit in the garage to charge EVs is a plus, and becoming more of a plus, having a 60 versus 50 amp circuit won't make much difference to buyers. What will probably make a difference in the future is having a 100 amp circuit for EV charging. For a Ford Lighting, Hummer EV, probably for the new Cybertruck, and other vehicles with larger batteries, being able to charge at up to 80 amps can make a significant difference.
I think it's quite clear, at least to me, that you would recommend the wall connector. But it's OK to admit that there are other charging setups that work fine for some folks.You have two options
1) Wall Connector
2) See #1
Tesla dropped the mobile connector and the 14-50 adapter to save money and because more and more buyers already had charging options. It had nothing to do with either being obsolete as you stated.Tesla dropped including 14-50 with new cars a while ago.
You obviously don’t know much about wall connectors. To change amperage you just turn a dial. On mobile you have to buy another adapter.
Let’s say you add more load to you panel. And want to turn down wall connector. Just dial it down. Or you get a new panel and want to up grade. Just turn it up. Get second Tesla just pair another to the same circuit.
Wall connectors or mobile connectors don’t generate heat (just a tiny bit). That’s why they are call “connectors”. There is no inverter in them. I guarantee a wall connector has a much wider operating range than a mobile connector.
Besides, Where is it specified a mobile connector can go in a box?
Your just making stuff up.
Operating specs are identical.Tesla dropped the mobile connector and the 14-50 adapter to save money and because more and more buyers already had charging options. It had nothing to do with either being obsolete as you stated.
So, you pull off the faceplate, change the dial, and put the faceplate back on with a wall connector. Actually, with the new wall connectors, I thought this could be set with the Wi-Fi connection. With a mobile connector, you unplug one $35 adapter and plug in another one, which you'll probably never do. In any case, both are pretty simple and not a valid argument for one versus the other for something that is done so infrequently.
You state that, "I guarantee a wall connector has a much wider operating range than a mobile connector." Please provide your proof to backup this statement.
With a wall connector, the unit is fixed in place. If you have a box, it will stay in the box. A mobile connector plugs into a socket in a box; it doesn't have to stay in the box while being used.
The only person making stuff up here is you. I've stuck with facts while you're tossing out your opinions out like they're facts. Sorry, but they're not.
Thanks for acknowledging that you were incorrect when you stated that, "I guarantee a wall connector has a much wider operating range than a mobile connector." Also, I wasn't sure, so I looked it up. Tesla shows that both the mobile and wall connectors don't require ventilation, so I assume that it would be okay to put either in a box.Operating specs are identical.
Gotta get work done. So blocking. See ya.
Why should I set the max charge rate to 12 amps. The 240 volt line is a dedicated line off of it's own 100 amp circuit breaker. I have been charging at 32 amps since I had it installed. There have been no problemsI assume that you're setting the max charge rate via the car to 12 amps, since otherwise the mobile connector would try to draw 32 amps from the wall.
You said that, "It has a whopping 15 amp service." which gave me the impression that that was all the circuit could handle, so 14 gauge wiring, 15 amp circuit breaker, etc. If everything on the circuit is rated for 100 amps or even 50 amps, that's an entirely different story.Why should I set the max charge rate to 12 amps. The 240 volt line is a dedicated line off of it's own 100 amp circuit breaker. I have been charging at 32 amps since I had it installed. There have been no problems
I vote wall connector, easy to install if panel in the garage. Waterproof, has built in safety.1st things 1st: Yes, I searched the for this topic before posting. I only found 1 in the Model Y section.
OK, further details. The barn dates to 1906. It does not have circuit breakers. It has an original equipment fuse box with room for 1 - yes, just one - old fashioned 15 amp glass fuse. To upgrade electrical service in the barn requires a trench to be dug across at least 75 feet of lawn in order to upgrade the wiring that leads to the barn. Then, a new circuit box needs to be installed in the barn. It's just not worth it, hence the use of a 240 volt outlet all-weather on the side of my house and a 14-50 Nema connector into which I plug my mobile connector and charge the car at 32 amps, getting 29 miles of range per hour. More than enough for my needs. If I want to charge the car on the existing 15 amp service in the barn I will get about 2 miles range per hour. Not enough for my needs.You said that, "It has a whopping 15 amp service." which gave me the impression that that was all the circuit could handle, so 14 gauge wiring, 15 amp circuit breaker, etc. If everything on the circuit is rated for 100 amps or even 50 amps, that's an entirely different story.
