The install of my 15.12kW solar system and 4 powerwalls was just scheduled for June 22nd, so I need to make a final decision about the powerwall location. My system layout looks like this:
The green mark is where my meter is and the red mark is the logical place to put the powerwalls. That is a garage wall, so the powerwalls could be put on the inside of the wall inside the garage or on the outside of the wall outside the house.
Here’s a picture of the outside of that wall:
As I see it, the pros for inside the garage are:
- The powerwalls will be subject to the temperature extremes that they would see outside, but it is a north facing wall, so they shouldn’t really get a lot of direct sun outside. Extreme cold shouldn’t really be a problem in or out of the garage here in Florida.
- They would be secured so they would be less likely to be vandalized or stolen. However, this is really a very safe area and this isn’t really a concern for me.
The cons for inside the garage are:
- Losing a fair amount of garage space. I am using the area where the powerwalls would go for storage right now and I would need to find new places to store that stuff with powerwalls there.
- Slightly more complicated conduit run as they would need to go through the wall, although I’m not sure that’s a really huge concern.
So what do you think? Would you put them inside the garage or leave them outside? Is there anything else that I should consider that I missed?
