Help me understand kWh used
Discussion in 'Model X' started by bell2041, Jul 23, 2018.
  1. bell2041
    bell2041 Member
    Brooklyn
    This is a 75D Model X. So my math is 100% is 75kWh, my last charge was up to 90%(67.50kWh), now the car at 55%(41.25kWh) so "Since last charged kWh" should be 67.50-41.25= 26.25kWh, but it says 19.90kWh
    Thoughts?
  2. P85_DA
    P85_DA Supporting Member
    That number is only your driving usage ..not sure if u have cabin overheat on etc ...vampire drain from car sitting there is also not counted in that number
  3. bell2041
    bell2041 Member
    Brooklyn
    so you mean that 19.90 kWh used only for driving? not including AC/Heat use when car is parked, etc?
  4. skraid
    skraid Member
    NJ
    Exactly
  5. dethman
    dethman Member
    socal
    that's a lot (7kwh) of extraneous drain.
  6. P85_DA
    ~13-14 miles not bad ...OP didn’t say how long car was sitting etc
  7. eladts
    eladts Member
    Brookline, MA
    Also, 75kWh is the nominal capacity of the battery, not the useable one. There are buffers above 100% and below 0% to protect that battery.
  8. Uncle Paul
    Uncle Paul Well-Known Member
    Canyon Lake,CA
    75 battery is slightly less than 75. Think it more like a 73 or so, rounded up to 75>
  9. animorph
    animorph Active Member
    Scottsdale, AZ
    Many many threads on this. My favorite answer is that you get more energy out of the battery if you take it out slowly. So your calculation should look closer to advertised capacity if you just travel at 25 MPH steady-state. And the kWh added during charging will probably be closer to the real battery capacity than the kWh measured coming out of the battery, which will depend on how you drive. One reason is the internal resistance of the battery. The more current coming out of the battery, the higher the internal losses, which are not captured by the measurement you are seeing.
  10. animorph
    Scottsdale, AZ
  11. hill
    hill Active Member
    Lake Forest, CA
    I've seen worse, especially during updates. And for the OP, don't forget (or, fyi) your 75 Tesla does not actually have 75kWh's usable - even if it were brand new straight off the manufacturing floor. iirc, it's ~72kWh.
  12. bell2041
    bell2041 Member
    Brooklyn
    I like to leave my car with "keep AC ON" (for like 10-15 minutes at a time), so I wanted to find out how much does AC actually uses, I guess it's 7kWh :)
  13. unpollo2
    unpollo2 Member
    atlanta
    i do this all day i'm out, i find it is very efficient like 3 miles an hour drain, but i set the fan to 3 or 4 and recirculate on
