Hello, I need some electricians help here because I'm between a rock and a hard place. I had Tesla solar and powerwall installed a few months back. After the install, and after PTO, I had a NEMA 14-50 outlet installed for my Model Y. Every circuit in my house, except for A/C is backed up by the PW on a separate subpanel. The A/C remains on the main panel and is fed by solar when available. All installs performed by licensed electricians.
My problem is after the 14-50 install, I noticed the daytime spikes from charging the MY at noon was not showing in my Tesla app. I went into my utility website and noticed I was pulling from the grid during clear daylight hours when I'm charging. I concluded that my charging off the 14-50 was not being powered by solar. The circuit is located next to the A/C circuit in the main panel.
Problem is my electrician can't figure it out. And I can see his point as I would have expected anything in the main panel would be covered by the solar panels. I have a hell of a time contacting someone at Tesla that knows the answer to my problem. Thoughts??
