Help... range issue
Discussion in 'Charging Standards and Infrastructure' started by SSD420, Nov 7, 2016.
  1. SSD420
    SSD420 Member
    ON, Canada
    It's 1 degree Celsius and I'm trying to get home. I have 160 km rated left. I have 102km to go. Model X 90D.
    I'm using AP, going 5km over the posted limit. No heat (I'm cold!) and my rated range is dropping fast.
    I've checked and re-checked plug share. Anything on my way either isn't open or is a home charger and it's 4am). What do i do?
    Is there anything I can do to use less energy?
    I have my dogs with me to top it off, and I feel bad for them (they are wrapped up in blankets and pillows together and they have fur, I don't)
    Suggestions??
  2. SSD420
    SSD420 Member
    ON, Canada
    Is AP more efficient than me?
  3. Electric1
    Electric1 Member
    NJ/Lehigh Valley PA
    Slow down. The slower you go, the less energy you use.
  4. SSD420
    SSD420 Member
    ON, Canada
    So side streets instead of highway?
  5. Electric1
    Electric1 Member
    NJ/Lehigh Valley PA
    Not necessarily, but perhaps 5 under as opposed to 5 over posted
  6. SSD420
    SSD420 Member
    ON, Canada
    Highway was closed, so that decision was easier.
  7. SSD420
    SSD420 Member
    ON, Canada
    So 5km/h really makes a big difference?
    What about 10 under? 15? When will I notice a real difference?
  8. SSD420
    SSD420 Member
    ON, Canada
  9. Hotlobstah
    Hotlobstah Member
    Cape Cod
    Worst case scenario, but if there is an open business(minimart, gas station...) maybe you can plug into their 110 outlet. That will at least keep you warm until you can find an open home charger.
  10. wycolo
    wycolo Active Member
    WY
    What are your miles remaining? To save my a$$ I go 36 mph until traffic approaches when I increase speed so they can pass me safely. Then back to 36 mph using cruise control. You can sit on one leg at a time to warm it up - the floor is COLD. Good luck!
  11. SSD420
    SSD420 Member
    ON, Canada
    Thanks guys for the support. I made it! Barely! I've never been this low before.
    This will be my first winter with an EV.. I'm starting to learn - the hard way.
  12. SSD420
    SSD420 Member
    ON, Canada
    I pondered this, dropping right down to a trickle, but wondered if it would hurt me in the long run, when it came time to go uphill
  13. wycolo
    WY
    25 mph is approx the most efficient speed but 36 is not that much worse while giving a sense of actually moving!
    Climbing hills requires no adjustment to methodology. We need to know your final miles else this never happened. :rolleyes:
  14. SSD420
    SSD420 Member
    ON, Canada
  15. SSD420
    SSD420 Member
    ON, Canada
    54km rated range left. Chattering teeth and frozen toes to go with it.
    How much range am I saving when I freeze my ass like this?
  16. SSD420
    SSD420 Member
    ON, Canada
    The floor IS cold!
  17. wesley888
    wesley888 Member
    Huntington Station, NY
    Someone in a website tested the heating scenarios. Using heated seats instead of the cabin heat is more efficient. Also, like other said, driving at 25-30 MPH (40-50 km/h) is the most efficient as well. I can try to look for the site again to get you some numbers.
  18. Missile Toad
    Missile Toad Member
    Houston
    Based on your picture response to:
    Did you actually complete your leg of the trip with 54km (rated) remaining? My math indicates you used 104 rated km on a distance of 102 km. So what was your average speed through those 104 km? 65 km/hr? (~40 MPH).
  19. lance
    lance Member
    Montreal
    56Kms? You had tons left. I've pushed a lot out of necessity over the years. Driving from Gaspe to Montreal over Xmas last year was the toughest push I've ever done with dog and family in the car. Kept the heat on and always arrived at a charge point with about 5% or less or about 20kms of range. Closest I've come to running out was last week in Wyoming....
  20. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    What did the energy app - trip setting - predict for the energy remaining in your trip? It does a decent job of considering temperature and elevation into the energy required for a trip. I suspect you were in much better shape than you thought
