Hello, I'm getting a very strange sort of warbling sounds that appears related to my Roadster's Alpine head unit. You can listen to it here, recorded in my dashcam: At first, I thought it was my dashcam, but it isn't. If I select FM radio on the head-unit and re-tune, the warbling is briefly interrupted, until the new station is found. Then it comes back. And it continues for different times, almost as if it is picking up interference from somewhere. To aid me in debugging this, has anyone else had this problem? Is there any way I can simply switch off the head-unit when this problem occurs, so as to be sure it is responsible. It's a real PITA, as you can imagine! Eugene :redface:
There is a speed camera close by, not necessary on the road or direction you are going:cursing: You can turn it off or turn down the volume in the navigation menu.
