HELP, stuck at a supercharger with 5 people and it's not charging!
Discussion in 'Model S' started by Brandon332, Aug 18, 2016.
Tags:
  1. Brandon332
    Brandon332 Member
    Hey guys, I need help. At a supercharger with 5 other people needing to come back from a road trip. 8 Miles to empty and the car isn't supercharging. The light on the charge port is green and blinking fast. The dash says "supercharging, 1 hour left" but it has been at 8 miles remaining for almost a half hour. It says charging at a rate of 3 miles per hour, voltage is high but amps are at 0. It's weird, the amps will rise from 0 to about 35 quickly, stay for a second then go back down to 0. I tried other stations at this charger and other people were here so it isn't the location. Thoughts? No Tesla centers are around HELP PLZ :)
  2. emir-t
    emir-t Member
    Istanbul
    Reboot the car unplugged pressing and holding both the buttons on each side of the steering wheel. If that doesn't solve it, call Tesla for help.
  3. dehydratedH2O
    dehydratedH2O Member
    Silicon Valley
    How do you think we can help? Call Tesla.
    • Funny x 2
  4. 180r
    180r Member
    Norcal
    Call the phone number on the charger.
  5. Dan43
    Dan43 Member
    Vancouver, BC
    I'm sure you have tried but have you connected to other SC in the same area? Is there a CHAdeMO or another non Tesla option or is your thinking it is the car having the issue?
  6. AEdennis
    AEdennis Active Member
    Which supercharger and did you try a different stall?
  7. Brandon332
    Brandon332 Member
    Tesla is going to take care of us. But has anyone else has experienced this issue before?
  8. Brandon332
    Brandon332 Member
    Tried a different stall and it's one in MA
  9. Saghost
    Saghost Well-Known Member
    Delaware
    What are the conditions like where you are? What had you been doing with the car right before? I've read in the past about something sorta similar happening when the car had to heat or cool the battery before it could safely charge.
  10. Brandon332
    Brandon332 Member
    Drove about 150 miles on the highway prior. Probably 80mph on auto, 76 degrees out.
  11. emir-t
    emir-t Member
    Istanbul
    Have you tried rebooting ?
  12. privater
    privater 2016 Model S and 2017 Model 3 owner
    #12 privater, Aug 18, 2016
    Did you encounter the same problem like me?
    Very frustration, I was intend to record a S60 charging from 4%-100%, but fails because of charging problem
  13. Victor Liu
    Victor Liu Member
    Westfield, NJ
    When it happened to me in CT last weekend, Tesla asked me to shut down the car from the screen instead of rebooting. It worked. It was blinking green with 0 AMPS. 2 minutes after the car was turned on it started charging normally. it was not immediate.
    Temperature was 100. Was driving for about 2 hours from NH.
  14. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    Why did you post twice?
    What did tesla say?
  15. Brandon332
    Brandon332 Member
    How do you shut down the car from the screen? To all: I posted twice because I was desperate. What ended up happening is that it started charging but after 45 minutes. Not sure what happened. I was still on hold with tesla so I just hung up.
  16. Brandon332
    Brandon332 Member
    Yes the problem was the same! Did u find a resolution?
  17. jerry33
    Texas
    Press the controls button, then the bottom tab (at least it's the bottom one on my car) on the left and you'll see "power off".
  18. xav-
    xav- Active Member
    Orange County CA
    Try control alt delete
    • Funny x 11
  19. ReddyLeaf
    ReddyLeaf Member
    Pasco, WA
    I have experienced something similar. It went to full voltage, started to increase amperage, but then decreased back to zero. I switched to another stall. I'm starting to think many of the connectors are getting corroded or dirty. This could explain many of the complaints about "throttling" in CA.
  20. Mike K
    Mike K Member
    Los Angeles
    Can you elaborate on the throttling issue?
