R
ReddyLeaf
Guest
Some California Superchargers not providing maximum charging ratesCan you elaborate on the throttling issue?
Yes the problem was the same! Did u find a resolution?
Not so. That's why your post got so many dislikes.Plugging in at below 10 percent and above 90 percent charge will charge more slowly to balance the battery. Typically keep mine charged between 20 and 80 percent, so never encounter these 'slowdowns', but then I also charge at the office and occasionally @home. Also, as stated earlier, the battery may need to cool down/warm up before charging ramps up again due to keeping the battery in the optimum temperature range while supercharging.
Don't make stuff up. There's nothing about starting a charge below 10 percent that would slow a supercharging session.Plugging in at below 10 percent and above 90 percent charge will charge more slowly to balance the battery. Typically keep mine charged between 20 and 80 percent, so never encounter these 'slowdowns', but then I also charge at the office and occasionally @home. Also, as stated earlier, the battery may need to cool down/warm up before charging ramps up again due to keeping the battery in the optimum temperature range while supercharging.
"Hello, Tesla. Have you tried turning it off and on again?"Very funny!
How do you shut down the car from the screen? To all: I posted twice because I was desperate. What ended up happening is that it started charging but after 45 minutes. Not sure what happened. I was still on hold with tesla so I just hung up.
Chargers are paired A and B. If you are the first person in a pair, you get the full charge based on the state of charge of the battery. If you are the second person, you get what's left over. Note that pairs may not be next to each other. That is the can be installed 1A-1B, 2A-2B,... or 1A,2A,3A,4A 1B,2B,... You have to look to see which is which. So if someone is plugged into 1A, you should not plug into 1B for the quickest charge.Can you elaborate on the throttling issue?
Exactly the same thing happened to a guy at the new Folsom SC. I plugged into 3A and he asked me what I was charging at. He was in 1B. 1A was empty. He returned to his car because when he checked the app it said 5hrs till charge complete. He moved to 1A with same result. Then moved to 2A and normal charging was available.My car did exactly the same thing, but only in one place - Las Vegas. I was on a 2 week burner of a cross country trip.
It happened on both A and B of only one charger, I think it was 1A and 1B, but plugging into another number the car charged fine.
I came back to this charger later that day after driving around, and had the same issue.
Then another driver plugged in and charged fine in that bay. (I asked.)
Yes, but this doesn't say anything about slow charging below 10%.I wasn't making stuff up.
"Charging from 10% to 80% is quick and typically provides ample range to travel between most Superchargers. Charging from 80% to 100% doubles the charge time because the car must reduce current to top off cells. Actual charge times may vary."
and
"There are many factors that affect the actual charge rate, including ambient temperature, utility grid restrictions and charging traffic, amongst others."
Source for both quotes: Supercharger | Tesla
and
"I am Supercharging, but not as quickly as I expected. What could be happening?
Your Tesla vehicle and the Superchargers communicate to select the appropriate charging rate for your car. Supercharging rate may vary due to battery charge level, current use of the Supercharger station and extreme climate conditions. Your Tesla vehicle charges faster when the battery is at a lower State of Charge, and charging slows down as it fills up. Depending on your destination, charging to completely full is often not necessary."
Source: Supercharging
There is also a forum discussion that references rates, and cites being less when BEV charging is started below 10%.
Model S supercharging times compared S60, S70D, S85, P85D, S85D | Tesla Motors
Where? Where random forum owners are trying to fit a curve to the SpC graph and have a formula for it? Due to them having a piece-wise formula with below 10% and above 10%? That doesn't mean it charges slower.
