Hi all,
I have a late-April 2017 build Model S with glass roof (not pano sunroof). I'm having some trouble running the rear camera cable cleanly on a Blackvue DR650S-2ch install. Any advice would be appreciated -- I watched DÆrik's YouTube video on this install but am still struggling. He made it look easy (and perhaps it is with the pano sunroof).
Rear hatch: I understand I can run the cable through the higher of the two flexible tubes there, but not sure how to get the cable out once I run it into the door. Is the only solution to remove all of the plastic trim, including the very large bottom piece around the latch, from the hatch door?
I had the most difficult time bridging the gap between the lower piece of trim (which I removed) and the glass roof. I can get a very thin twist-tie through and tie it to the cable, but when I try to pull the cable through it keeps getting caught on something. I had no luck getting a coat hanger through. I can't for the life of me figure out what its getting snagged on, and of course there doesn't seem to be a good way to see anything. After about 1.5 hours I put the trim back.
Windshield: it seems that the plastic housing around the cameras and roof trim along the top of the windshield are very tightly attached. I tried a plastic spudger but started to become afraid I would break something trying to pry it. Any ideas?
Thanks in advance.
Thanks in advance.
