Just installed the 4.2 frunk kit in my 2018 Model 3. Everything's working, but when the frunk is closed the driver's side of the frunk is pulled down significantly (3.5mm) lower than the top of the quarter panel. I've tried adjusting the mounts to compensate for it, but it hasn't helped. Even when I move the lock way up (so the closed hood is much higher than the body), that driver's side is still pulled low. It's definitely the strut contracting too far.
Some of the ever-changing, ever-confusing, never-current Hansshow documentation shows a controller that has strength, height, and speed adjustment. Unfortunately the new waterproof 4.2 controller doesn't have the button shown in those instructions.
I'll contact Hansshow but figured I'd try here first. And of course when/if I figure it out I'll post the solution here. Cheers.
