Hello everyone. I've found threads on this on different forums but I find such a vast gap between opinions.
I just bought a gas pressure washer today, 3000 psi and ~2.4 gpm, 25 degree nozzle and an MTM Hydro Pf22.
I was wondering what PSI I should use with the 25 degree nozzle when washing or rinsing the car. Then what psi should I use with the MTM Hydro 1.1mm fitting attached? I'd like some visual pleasure blowing my load of foam on the car.
Also the guy at Lowes told me to use gas without ethanol but the manual says up to 10 percent ethanol is okay? Is there a huge drawback to using gas with ~10 percent ethanol?
First time I'll be using a pressure washer anywhere besides a driveway.
Thanks!
Thanks!
