Help with Power Meter and Vampire Drain
RUK MINI
5
0
Racine, WI
I bought excitedly a new Model S LR in Dec 2019. Have a Tesla Wall Charger running from the breaker panel. Still learning about charging limits, battery degradation, phantom braking, vampire drain, ghost cruise, monster space, etc. from these discussions. I am running 2020.32.3.
Need help on two fronts please:
(1) What is the good value-for-money approach to know reliably how many kW I am actually pumping into the car when I plug it in? For security reasons I prefer not to use 3rd party software like Teslafi.
(2) The vampire drain surprises me! For 10 days I had not moved my Tesla out of my garage (lovely weather so used my Miata a lot). . but the charge level dropped from 85 to 68%! That is 17,000Wh consumed in 240hrs which is 70Watts drained each hour. Sounds realistic?? Very surprised/disappointed. Sentry Mode is off; relatively cool temperatures in upper midwest. What's going on? At 17kW-hr per 10 days drain, am I looking at 50kW-hr of vampire drain per month, or half-a-tank of electricity poof every month! Wow.
Thanks for any help. . .
beatle
968
471
Springfield, VA
You've painted yourself into a corner by eliminating the best option for this: TeslaFi. You could install a power monitoring piece of equipment called Sense in your panel. That will give you intel on how much power is coursing through your home's circuits, including the circuit for your wall connector. Of course that costs a lot more than TeslaFi and provides a lot less detail on your car's energy use, though it has other benefits in your house.
I burn through 1.5 - 2.5 kwh per day of vampire drain. I think a big part of that is because I am constantly polling the car with TeslaFi and I do not allow the car to sleep (it's annoying to wait for the screens to boot up). I find it's a convenience worth shelling out a few bucks a month for.
E30M3
14
11
Santa Clarita
There are wall chargers available from companies other than Tesla that record the energy consumption during the charge event. I personally use a OpenEVSE unit that has a readout on the EVSE and can communicate with a webapp. I know there are also units available from Enel X and ChargePoint that also have webapps, but I'm sure they aren't the only ones.
Alternatively you can set your car to notify you when it starts and stops charging. Mine tells me the starting battery percentage and ending percentage when it charges. That would give you an indication of vampire consumption but will be less accurate than the EVSE with a current transducer but is much cheaper.
Joel
