Help with pw2 tcs setting in wizard
Discussion in 'Tesla Energy' started by Big Todd, Aug 24, 2018.
  1. Big Todd
    Big Todd Member
    Newcastle
    Hello I just bought a home with a Tesla system,
    My story
    The wifi changed and lost pw2 connection to net . The pw2 needs some new hardware for cellular. Still awaiting parts . So with the help from a pw tech we accessed the wizard from my tablet and here is the problem.
    Problem ...
    The wizard didn't know or auto populate the 4 tcs sensors .. so we left it as is .. my battery is still in park mode.. lol .. 2 months of Tesla phone calls and here I am .. is it possible to remove my panel covers on my old main and or new to see these couplers and right down the Id and location .
    If I do what order are they entered? There is drop down menu choices.. Main, solar, battery,draw is this a good guess ..
    Any knowledgeable help would be appreciated.. I have only found screen shots of the wizard around the web but nothing showing how to diy the tcs .
    Thanks again for your help
    Todd
  2. cwied
    cwied Member
    San Mateo, CA
    I assume you mean "CTs," (current transformers) not "tcs."
    I don't know if it varies from installation to installation, but here's how they configured the CTs for mine:
    You should be able to figure out what is what based on the current flows and knowing whether your solar is producing or not. Try turning loads on and off in your house to find the ones that are measuring site current.
    Edit: I just realized you're in the UK, so it's quite likely your CTs are hooked up differently since you don't have split-phase service like we do. You might be able to look at your electric panel and just find where they are to understand what they are measuring.
  3. JohnRatsey
    JohnRatsey Member
    UK
    My PW2 (in UK) is measuring:
    1. Mains power
    2. Household power
    3. Solar power
    4. Battery power (not sure if this needs a CT or is built in to the battery)
    Regarding the lost internet connection, my installer opted to use a pair of powerline adapters so that the gateway could have a wired LAN connection and thus sidestep any WiFi headaches.
  4. cwied
    cwied Member
    San Mateo, CA
    I believe all Powerwall installations (with solar) report all four of those. The battery power is built-in, I believe. The rest is calculated using the solar and site flows in my case.
  5. Big Todd
    Big Todd Member
    Newcastle
    I'm in the USA .. at the meters page it says unable to read meter in red .. detect meters doesn't work..
    On the continue screen. I get the current transformers page ..
    It says meter 1
    Then 4 cts drop down all with no reading .
    On the 4 drop down choices are site solar and load and none .. I will pull my panel covers and inspect more ..
    Thanks again for your help .
  6. cwied
    cwied Member
    San Mateo, CA
    I believe the meter is the Neurio that's in the Gateway box. If the Gateway can't talk to the Neurio, that would explain why the CTs aren't showing anything. It sounds like there's something more basic not working in your system than just the Wifi switch could explain.
  7. Big Todd
    Big Todd Member
    Newcastle
    I
    Think your right .. does this gateway neurio self install into the wizard or do I need to enter some id number or something to get it recognized..
  8. miimura
    miimura Active Member
    Los Altos, CA
    I believe the Neurio and the Powerwall(s) talk to the Tesla Gateway over RS-485. There could be a cabling problem with these communication lines if the CT's are not showing up in the Wizard.
  9. Big Todd
    Big Todd Member
    Newcastle
    I spoke with another tier one pw2 tech today and he confirmed my early version of pw2 has some known hardware issues that cause it to be parked when it lost its old wifi .. now the gateway is not communicating with the main sensor you speak of ..neurio ..
    Hope they can get to me soon
