Just to let Model X Owners know that although you did not take the HEPA Air filter option, it seems everyone can just add the filter in the box located at the back of the frunk...
Interesting. So it looks like the 12V battery jump point is there on the upper left. Did you see where the 12V battery itself was? )
Without the software for biodefense mode will the hepa still work?
Thanks for the advice! I didn't opt for premium and is only regretting not having the filters. Exhaust fumes on SoCal freeways are really bad. Lots of 15+ age cars on the road spewing the smog. I will try installing the hepa.
Just because you can put a filter in there doesn't mean you can use it. (Does it pull air through that area without turning on the software biohazard filtering mode?)
I was thinking the same, but the instructions to the car indicate otherwise, stating that HEPA is enabled when BioHazard is pressed.I'm pretty sure the only thing selecting Bioweapon mode does is go to all outside air at high fan speeds to generate the positive pressure (still not sure if it does anything to the normal cabin exhaust vents at the rear of the car to help build pressure.)
