This is very poor advice.if you have a 32A commando its going to draw max 7.4 kw on a single phase, most homes in UK are single, its very rare to see triple phase unless you're a commercial building or you're next to one that shares the same line, especially on old build homes, just wont see it 100%! 32A commando going to work the same as a e.g gen 3 wall connector, as you're likely to be limited 7.4 kw, save that money. all these fancy wall chargers is just a management system to tell you its charging from your phone, you can just look in your car then go to sleep, its still going to take a long time to charge but at least you'll be paying for a low rate. fyi. mine only cost £460 plus labour (buckinghamshire) hope this saves you all money if you're looking for solution, as this is the cheapest solution I've found which makes sense. if you think paying about double of what I got mine for a smart charger to tell you, its charging then thats madness, but if your setup can actually pull more than 7.4kw and you're in need for speedy charging then yeah spend the money.
There are many threads on this forum with sound advice from qualified electriclans on this subject.
As more folk join the EV revolution they 'discover' cheap charging 'solutions'.
The post above is not the answer for long term regular charging.
