Even if they only cost $10 each to produce, that's $80 additional to the cost of the car and probably $400 to the selling price.It's a diode, some copper, and a injection molded plastic housing. They can't be *that* expensive.
Ten adapters less the two that are already there make eight new adapters.Wait, how? I'm not following. What's wrong with making the adapter for $10 and getting the customer to buy the ones they need at $45 a pop?
I'm not sure why every owner needs every adapter.Ten adapters less the two that are already there make eight new adapters.
Agreed. I would like to see a 14-30 and a 6-50. The others are out there but these 2 are the most common that I have found.I'm not sure why every owner needs every adapter.
I'm not either, but the suggestion above was to include all adapters with every car.I'm not sure why every owner needs every adapter.
Yeah, but no one was really taking that suggestion seriously.I'm not either, but the suggestion above was to include all adapters with every car.
Right, but how can Tesla be sure that everyone flips the switch appropriately. It's the same problem as using a cheater adapter. There's some liability here for Tesla if they make such an item.Another thought: I'd be happy with a 14-50 adapter with a switch on it that I could use to dial down the available amperage. That way I'm not reliant on the car I plug in to do it for me.
They can't. I'm not saying it's an ideal answer, but it's much better because as long as I leave that charger plugged into a 30 Amp circuit, I can be sure that no Tesla will try to draw more than the 24 amps that's available.Right, but how can Tesla be sure that everyone flips the switch appropriately. It's the same problem as using a cheater adapter. There's some liability here for Tesla if they make such an item.
Because of economies of scale. Tesla clearly doesn't want to produce unpopular adapters, the only solution is to make adapters the exact same popularity, or the adapter that only 10% of owners want does not get produced.
This explanation would have made sense until they came out with the 6-15 adapter a few months ago, after the 14-30 and 10-30 were discontinued. Who uses a 6-15 adapter? The demand for the two discontinued 30A adapters must be at least an order of magnitude greater than the demand for a 6-15 adapter.Because of economies of scale. Tesla clearly doesn't want to produce unpopular adapters, the only solution is to make adapters the exact same popularity, or the adapter that only 10% of owners want does not get produced.
This is not a good issue. They could simply stop selling them individually, make a "charging kit" so they'd achieve volume production on every type, and include 10 of them in the kit.
Every adapter is nice, but not completely necessary. Over 4 years and 80K + miles I have likely used most adapters at least once. It is a nice peace of mind to know that if you find electricity you can charge from it.
Not saying this is practical, but a mechanical switch could conceivably change neutral blades at the same time it changes resistors - might be a bit more bulky than the current units.Right, but how can Tesla be sure that everyone flips the switch appropriately. It's the same problem as using a cheater adapter. There's some liability here for Tesla if they make such an item.
All you need is a 14-50 non-conductive neutral blade that is spring-loaded on a low-voltage switch. When you plug into 14-30, you flip to the right amperage signaling.Not saying this is practical, but a mechanical switch could conceivably change neutral blades at the same time it changes resistors - might be a bit more bulky than the current units.
Would have been very nice. I passed on buying a JESLA because my install had a 40a breaker on a 6-50 receptacle. I instead went with an OpenEVSE which I can set to any amperage.Another thought: I'd be happy with a 14-50 adapter with a switch on it that I could use to dial down the available amperage. That way I'm not reliant on the car I plug in to do it for me. I think the biggest problem here is there are no connectors limited to 24 amp draw....it's not that a specific plug isn't available.
