Interesting. Mine says 3PH. And it has 4 orange cables labeled N L1 L2 L3. View attachment 247882View attachment 247883
No, single phase is common in Australia. I have single phase in two out of three homes.3PH: 3 phase-power charger. Different from North American spec Teslas. This thread doesn't apply to your car
You'll find this charger on basically all the non North American Spec Teslas since basically only USA/Canada/Mexico use single-phase power in residential homes.
In North America, 3 phase is never found outside of industrial/commercial applications.No, single phase is common in Australia. I have single phase in two out of three homes.
I also have the original HPWC (single phase only) at one house, and a new HPWC (single or three-phase) at another house.
Mine (100D) also says it (included). The price isn't there, just included. So, wasn't there a recent change for European models? I read something, but I can't/don't keep up the foreign market changes. I thought there was something about all models there getting the higher charger?My 75D Vin 213XXX (ordered on 3th august) has the "high amperage charger" option. It says "included" on my view spec PDF, no extra cost...
All you have to do is pull the back seat cushion up. Reach under the front lower edge of the cushion where it meets the carpet and feel left or right until you find the retainer bracket. Pull firmly upward to release the cushion from the bracket; there is one bracket on each side. Note: if the plastic retainer comes out with the cushion, remove it from the seat and snap it back into the bracket. To reinstall you need to align the seat belt buckles first and put the rear edge in. Next press the front edge down to engage the two from retainers, it may take some pressure to get them to snap in.
Yep, even Rich (of flooded car fame) showed us this in his videos, I believe. It really should pop right off. Wait, what service manual?! Unless you are also in Massachusetts....If I remember correctly, the service manual says to stick a screwdriver under the plastic part and pop them up through the mounting brackets. I tried this, and could not really get enough leverage for this to work. I didn't want to damage anything by just pulling up with my hands... With that said, everyone I've talked to (out side of tesla) seems to just pull up on the seat??
So if I have the 48A charger in my S75D what am I missing?
I think the superchargers still charge my car at the maximum rate, right? So the home charging is the only place I'm likely to be affected. With a 50A 240V connection, I get 33 miles of range per hour of charge and that's at 40A. When I visit family, I either use a 50A 240V circuit, using 40A, allowing the 33 mile/charge-hour, or I use a 30A 240V dryer electrical adapter. That 30A gets me 23 miles of range per hour of charge. The 72A charger won't help me away from home since I'm supply limited to 30A or 40A. If I use a supercharger, I think the on board charger is bypassed so I get the maximal rate the supercharger provides.
If I put in the Tesla home charging apparatus, I suppose I'm limited to using 48A. That extra 8A (compared to the plug in limit of 40A) would increase my charge rate by 20%. That should give me about 40 miles of range per hour of charging. I've noticed that increasing the amperage does increase the charge rate by more than the simple ratios would indicate, up to 40A anyway, and I assume that trend continues.
With a 75D I started with a range of 259 miles, that has rapidly dropped to 250 after the first couple of charges. So to increase my charge by 200 miles of range, the 33 miles per hour charge rate would take just a bit over 6 hours. At 40 miles per hour of charge, it'll take 5 hours. That hardly seems worth the expense or the effort to install Tesla's charger.
If I could charge at 72A, I should be able to cut the home charge time by 1/3, so that charge would take about 3 hours and 20 minutes.
I know I'm ignoring the slowing of charge as the battery charge passes 90%. Since the battery slows it's rate of charge at 90% of capacity, I'm guessing my 40A or 48A would at some point supply the maximum accepted, so the advantage of the 72A would probably disappear at 90% or so. So charging from 50 miles to 250 miles, then leaving out the top 10%, or 25 miles, leaves a difference of 1/3 of the time over 175 miles. So with Tesla's home charger installed that 175 miles of range should take me 4 hrs and 40 min (at 40 per hour). If I had 72A, I should get something over 53 miles of charge per hour, so 3.3 hours, or 3 hours 18 min. So I'd save about an hour and 22 min. Is this about right?
When I'm home I charge overnight so that 1 hour 22 min time savings really doesn't matter to me. It's unlikely I'll come home, sleep for a couple of hours then start a trip.
It makes me think that 72A charger isn't as important with the 75KWH battery packs as it might be with the larger packs. If the only place it would help me is overnight at home, I don't think having that 72A charger would make a bit of difference to me.
Yes, on the Swedish website it says that upgrade charger(16,5 kW) is standard on all cars order after the 30th June.Mine (100D) also says it (included). The price isn't there, just included. So, wasn't there a recent change for European models? I read something, but I can't/don't keep up the foreign market changes. I thought there was something about all models there getting the higher charger?
The service manual has a long drawn out process that I cannot possibly see how you could actually do with the seat in place. That absolute worst thing that could happen is that you could break the plastic retainer and you would have to spend $5 or so on a replacement one.If I remember correctly, the service manual says to stick a screwdriver under the plastic part and pop them up through the mounting brackets. I tried this, and could not really get enough leverage for this to work. I didn't want to damage anything by just pulling up with my hands... With that said, everyone I've talked to (out side of tesla) seems to just pull up on the seat??
Why did your range drop 9 miles after the first couple of charges? Should that happen?So if I have the 48A charger in my S75D what am I missing?
Do you have a source for that?Tesla recommends the battery being kept at a full (80%) charge. So that implies charging every night after use.
You are probably right, here are some more information and as you say, it's about keeping the battery around 50%.Do you have a source for that?
It is my understanding that lithium ion batteries last longest when the use keeps the batteries closest to 50% charged, so if one used say 20% each day, ideally they'd charge to 60% then use it down to 40% each day.
That 80% seems it should be an upper limit rather than a daily goal.
Honestly the question is probably moot because the 80% charge doesn't significantly decrease battery life, as I understand it. Also that 80% may be beneficial if it plays a role in balancing the batteries. So if Tesla has made that recommendation, I'd like to read it.
