High Bitrate Streaming Capability
Discussion in 'Model S' started by Black/Black MS, Apr 2, 2017.
Tags:
  1. Black/Black MS
    Los Angeles
    On the order page for the Model S it advertises "High Bitrate Streaming Capability" for the UHF Sound system. Presumably that's for Slacker radio. Is that a new thing, or is that something that works on earlier facelift Model S' with UHFS? If so, how do you enable it?
  2. boonedocks
    boonedocks Active Member
    Gainesville, GA
    I had a 2015 S85D standard audio with Reus upgrade. I don't remember seeing the high bit selector on it. My new S100D with UHFS does have the selector button under the sign in info at the bottom of the Slacker streaming screen. It must be a new addition for UHFS system for Slacker audio
  3. scottflys
    scottflys Member
    Argyle, TX
    You have to have the Premium account and you really can't hear the difference
  4. boonedocks
    Gainesville, GA
    I see what you are taking about. It is an option on my S100D with UHFS:
  5. Jashev
    Jashev Supporting Member
    Wrightsville, PA
    If you scroll to the bottom of the slacker screen, there is a checkbox to enable high bit rate streaming.
  6. Black/Black MS
    Los Angeles
    #6 Black/Black MS, Apr 2, 2017
    Do you need to purchase a premium account to be able to do that? All I see is the sign in option at the bottom of the screen.
    Edit: found it. You need to tap the "sign in" button, then it takes you to a log in screen and there's a "high quality bitrate" option on that page. Still unclear to me if that's active if you're not actually signed in to an account.
  7. Jashev
    Wrightsville, PA
    Not sure myself. Hard to hear the difference. I did find that with the premium account, if my changes don't show in the car, I log out and back in again and everything is there.
