Understood. I am humbled by the universal disagreement in my opinion. Having said that, I would still like to share my reasoning.
When one tries to understand the total cost to own a vehicle, that should also include the understanding that every owner will have a different result, especially when it comes to energy usage. This will be influenced by several factors, such as: charging methods, usage of preconditioning, scheduled charging, sentry mode settings, outside air temp, average speed, dog mode, etc.. This fact is exaggerated by the fact that EV’s don’t involve much maintenance and are super efficient. For this reason, personally, I want to understand that which is universal across all MY’s, the driving efficiency. This is the logical approach from my perspective..
For example, when it comes to preconditioning energy usage, I’m surprised more isn’t said about the benefits of charging just prior to departing. Pro tip, you can get rid of the regen dots (or many of them) by simply scheduling your charge so that it completes just prior to departure. Doing so can reduce/eliminate the need to precondition the battery, depending on ambient temps of course. I see many wanting to know how to only precondition the battery, this is how I do it with our MY and i3.. and the best part is that it doesn’t use any additional power since it’s simply a result of charging. Does everyone do/know this, or care about it for that matter, I doubt it... It would be super useful to see just how much heat is added to the pack by only charging from 40-60%, but my experience with doing so suggests that a noticeable amount of heat is produced, even when charging between 7-12kW only.
In other words, don’t assume that your overall energy consumption will be universal since there will always be a significant amount of variance that is dependent on several variables, many of which involve the operator and their approach, and/or the environmental conditions. So why bother evaluating for anything other than having for your own records? I don’t see the value of sharing this information as if it will always be the same no matter who the operator is, that will not be the case.
