The handle popped out fine, but the solenoid mechanism or latch that opens the door itself did not work:
This is way more concerning than cup holders...
We've heard that pressing and holding the top center of the FOB will open the windows (as I recall).
Yes, the door not opening, with the handle extended, is very concerning. The next time we get a low 40's night, I will leave the car out to cold soak and try again.
Thanks for all of this information. One question: I assume you didn't put gloves on after the handles came out, correct? If the inside of the handle has capacitive sensing for unlatching the car, then of course it wouldn't work. Just a thought.
Thanks for the tip. Yes, I just went out to the garage and did a test. One click on the top of the fob locks the car, double click on the top of the fob unlocks the car, and pressing and holding the top of the fob opens the windows.
I've had this 4 times already.....
I'm curious to know if it made any sound at all (i.e., like it was "trying to work"). Maybe just some sort of lubricant gets gummy when cold? If it made no sound at all, it sounds more like a bad connection.
... it went to 23,496 miles at one point...
So, how is the Cottonwood story going? Any updates?
Fun report. I live in Evergreen, CO so I am looking forward to using the regen braking while descending I-70 toward Golden/Morrison. Also, when it's open in the spring, I'm taking my Model S (due in Jan/Feb) up Mt. Evans at 14,256 elevation, which is the highest paved road in North America, so then I can claim the elevation record at that point. Congratulations! If you're toward Evergreen with your gorgeous S, let met know if you'd like to met up.
We should totally do a Tesla S caravan up Mt Evans next spring. Your idea, so you get to lead and claim the record.:biggrin: It would be fun and make a great photo op with a bunch of us in front of the sign showing the elevation. And on the way down we will try and set a new record for silly-high range numbers...
... I know because I ride my bicycle up the climb 3-4 times per year, inccluding the Bob Cook Memorial Hill Climb Race...
