High pitched whining/buzzing noise coming from front of car?
Discussion in 'Model S' started by HX_Guy, Feb 5, 2017.
Tags:
  1. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    I'm not certain when this started but I've noticed a somewhat loud buzzing/whining noise coming from the front end of the car both when the car is parked and while driving. It can clearly be heard from outside the car but you can also hear it inside the car. It seems to happen almost non-stop, though there are period where the car is completely silent, but it used to be silent all the time while parked.
    Anyone else ran into this?
  2. Romand
    Romand Member
    Chicago
    Its supposed to be like that everyones tesla does that do not worry ☺️
  3. Nietschy
    Nietschy Member
    Austria
    Sounds like a coolant pump to me.
  4. davidc18
    davidc18 Active Member
    Ft. Lauderdale
    unplug the headlights and see if it stops.
  5. dbhajek
    dbhajek Member
    San Antonio TX
    Mine definitely has a whining coming from headlights
  6. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    Are you guys sure this is 100% normal? I'm not understanding why this started just recently and why it seems to be happening almost constantly. Just this morning again I went to leave for the office and sure enough, the buzzing was there.
  7. grichard
    grichard Member De-Luxe
    St. Louis, MO
    Yes, I've heard the same confusing sound. You were probably sitting in a car other than your Tesla. It's a noisy piece of vintage technology that makes the car go. Don't worry about it. It'll be obsolete soon enough.
  8. MorrisonHiker
    MorrisonHiker S 90D 2018.26
    Colorado
    Is it the same as this? Refreshed Model S: constant buzzing noise?
  9. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    Thanks for the link - I think mine is probably related to the same as that thread. No way it's normal, especially since it did not do it the first few weeks of ownership.
  10. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    ISSUE SOLVED:
    I took the car to the service center and they found that the rear coolant pump was bad, which was causing the front coolant pump to run at 100%, which apparently also caused an issue with the Thermal Controller (this was the item causing the buzzing noise).
    Car is wonderfully silent once again. :D
  11. Romand
    Romand Member
    Chicago
    can you share what they did to fix it like what it says in the service invoice
  12. Pato
    Pato New Member
    Seattle
    @HX_Guy Thank you very much for posting, including the helpful video! I just ran into this same exact noise with my 2015 85D, and will be taking it into the service center asap.
