High Power Charger vs. J1772
Discussion in 'North America' started by JoeP, Mar 10, 2011.
  1. JoeP
    JoeP New Member
    So, the EV Project will be installing a ridiculous amount of public J1772 charging stations everywhere -- many where I live, SoCal.
    It seems like J1772 will be the standard, including Teslas (any word on the Model S?)
    I just got my Tesla :smile:
    Should I wait for the J1772 tesla conversions or install the high power connector in my garage? At the moment, I only have the NEMA 5 connector.
  2. Eberhard
    Eberhard #421 Model S #S32
    Germany
    Better wait until tesla will provide 3-phase charging, then you can do more then 20kW at 277V/32A.
  3. Kevin Sharpe
    Kevin Sharpe Active Member
    Bradford on Avon, UK
    Many people with HPC's find they rarely use the high power charging at home. At home most of the time I charge at 24A (240V) overnight.
    I would suggest waiting For J1772 because I think the Tesla connector will only be found on the Roadster.
  4. Kevin Sharpe
    I think the OP will have a long wait...
  5. Eberhard
    Germany
    Elon told in Milan, that Model S will be able to charge with more than 20kW at 277V maybe at least with 80A single phase. Currently 1 charge my Roadster with 32A home and 16A Office.
  6. Kevin Sharpe
    with respect, I do not believe we will ever see 3-phase support on the Roadster provided by Tesla. I'm also willing to bet you $100 that you won't see 3-phase support on the Model S from Tesla before the end of 2013 (if ever).
    I'm not opposed to 3-phase and would love to have it when traveling in Europe. However, with connector standards still trying to get established and with Tesla's US focus I just don't think this will happen any time soon. That said, I'm sure that after market 3-phase solutions will be provided as cars start coming out of warranty.
  7. Eberhard
    Germany
    JB Straubel promised to me to provide 3-phase charging for Europe. I think Tesla will support the Mennekes socket. a vienna-rectifier is cheaper, compact and more powerful, creating less noise compared to 1-phase high current rectifier, which needs more coils and caps.
  8. doug
    doug Administrator / Head Moderator
    Eberhard, though I agree with your sentiment (and I'm sure many others do), please stop hijacking every thread that mentions charging into another 3 phase discussion. It's unfair to the original poster and annoying to other readers since it is clearly not relevant here.
  9. richkae
    richkae VIN587
    Back to the OP:
    I put two Nema 14-50s in my garage ( 240V 50amp, max continuous current 40 amps ) and I charge my car exclusively with a mobile connector.
    When I get my Model S, I plan to charge it via a mobile connector plugged in to the other Nema 14-50 outlet.
    That is what I would recommend.
    I have never in the year and a half of owning the car needed to charge my car at home faster than 240v 40amps can do.
    I wouldnt invest in an HPC right now until we know how Tesla is going to solve the J1772 connectivity problem with the Roadster.
  10. dpeilow
    dpeilow Moderator
    Winchester, UK
    I'd say that buying an HPC now is fine - Clipper Creek will sell a conversion if or when you need to change the plug.
  11. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Good to know. I might just switch it over when the S comes. Seems to me I'd be more likely to use high power charging for it than for the Roadster. Bigger battery.
  12. SByer
    SByer '08 #383
    Cupertino, CA
    Even a 10-30 outlet in the garage will do (full charge overnight, not that I've ever really needed it). I was lucky - the laundry room is on the other side of the wall, so I tapped into that circuit and use the mobile charger. About $40 in parts (over the mobile charger) and about an hour of time (it's hard wrangling 10 gauge wire in a single-gang box - if I had to do it over again I'd go for the double-gang just for the room).
