Has anyone seen this yet? I plugged into the La Costa urban supercharger and this message popped up on the dash. It automatically set my charge limit to 80%. I was able to move it back to 90% but I’m not sure if it will still stop at 80%.
I agree it’s interesting to see them being able to implement it via software. I have seen the signs before as well, but had my doubts on how effective they are.I've been to ones with Tesla signs saying that this is a very in-demand station and usage is strictly limited to 30min. I didn't get to 80% to see if there was any battery limit as well though. I figured it was more of an honor code thing than a software thing, but this is kind of neat to see they can enforce via software if needed.
yes, I wonder if it really helps. Maybe they need a message of "WARNING, charging your car longer than 30 minutes at this charger will cause your battery to explode into a fireball thus resulting in an agonizing painful death for you"That's interesting. Not sure if that helps in any way getting people to move their cars.
Thanks for this tip. I'm at the Charlotte supercharger station while on a road trip and this message popped up. Annoying because I know for sure this station is used mainly by locals.Yep. If you just change the set limit above 80% it keeps charging past 80%.
Maybe not, but they're certainly able to change some of the rules to ease congestion, which appears to be what they're doing.Tesla doesn't get to complain about early adopters using the SC network for normal use just because they lacked the foresight to establish a policy prior to selling the product.
For these specific policy change, I don't understand how they expect to enforce the 80% limit? If you need 95% to make it to you destination, what then? Perhaps this will only apply in areas with multiple SC locations. Seems like the lack of forethought continues.
Not so sure about that. I have travelled ALL over the USA coast to coast several times and I have never needed more than 80% to get to my next destination or charger. I'm sure there is probably an unusual situation somewhere along the routes in America where this might be needed, but I haven't run across it yet. Frankly, I never want to charge above 80% anyway because I spend more time getting a lower charge rate above 80% than if I just get back on the road and charge at the next location a couple hundred miles later. Of course I am just talking about my experience in the MX 100. I can imagine this maybe being a problem with a 75 or even a 90 model.If you need 95% to make it to you destination, what then? Perhaps this will only apply in areas with multiple SC locations. Seems like the lack of forethought continues.
Sounds like if you have a destination in the nav that needs > 80% to reach, it will allow you to charge to the level necessary to continue your trip. Now of course that's a relatively easy hack to employ if someone is really has an axe to grind with this proposed change, but I expect 100% draconian compliance is not the goal. If it gets even 10% of people to move on sooner, it was worth the effort.
If you drove North-South in the prairie states you would need it because many of the SCs are 200 miles apart. North-South SCs are just not built out. I wouldn't call it unusual, because it's common, and there's no timeframe for when it might get better because the needed SCs are not even gray dots on Tesla's FindUs site.Not so sure about that. I have travelled ALL over the USA coast to coast several times and I have never needed more than 80% to get to my next destination or charger. I'm sure there is probably an unusual situation somewhere along the routes in America where this might be needed, but I haven't run across it yet.
You must have driven at 55mph on those trips. I’ve done numerous trips from NH to FL and from the east coast to the west coast on I40 and I10 and with detours off those highways. Once my P85 hits 75mph the battery range drops drastically. At higher speeds it is even worse...…. In short, there are some locations where it is necessary to charge above 80% to reach the next supercharger location (at least for me).
Specifically what route? I will make a note to avoid it. I thought I travelled that route recently, but maybe it another place other than what you mention. Most all of my travel is East West anyway. The only area I have needed to avoid is on I40 between Oklahoma City and Nashville where it is still practically impossible to travel by supercharger alone with any model Tesla at any speed. Maybe the 3 can now do it. I am amazed that hole still isn't filled yet. North Dakota.... another black hole.If you drove North-South in the prairie states you would need it because many of the SCs are 200 miles apart. North-South SCs are just not built out.
It also notified me through the app.Has anyone seen this yet? I plugged into the La Costa urban supercharger and this message popped up on the dash.
Try traveling from central South Dakota to south central Nebraska on only an 80% charge. Sure, you can charge to less than 80% and stay on the interstate but that will add several hours and hundreds of miles to your trip. If one spends a few more minutes charging above 80%, they can avoid driving hundreds of extra miles and get there hours faster.Specifically what route? I will make a note to avoid it. I thought I travelled that route recently, but maybe it another place other than what you mention. Most all of my travel is East West anyway. The only area I have needed to avoid is on I40 between Oklahoma City and Nashville where it is still practically impossible to travel by supercharger alone with any model Tesla at any speed. Maybe the 3 can now do it. I am amazed that hole still isn't filled yet. North Dakota.... another black hole.
